Thread: HVAC Issue, Stuck on Defrost/Lower Only, Help
Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
  1. #41 Re: HVAC Issue, Stuck on Defrost/Lower Only, Help
    SE Level Member 0dark30's Avatar
    Nov 2012
    Flint MI.
    Is there a T by the battery?
    1997 GTP coupe,
    40th Anniversary coupe.
  2. #42 Re: HVAC Issue, Stuck on Defrost/Lower Only, Help
    shouldn't be. it runs to the fire wall, then down the fender to battery area, then crosses the rad support to that vac ball there. from the vac ball it leads in to the cab some how.
    seems like your was taken off or forgotten about or something. if the line wont reach there any more, get some vac tubing, slide it over the existing plastic line, then run it to the top of the sc. if it worked rigged in, it should work where it belongs.
    vac tubing cost less then a dollar a foot too. very cheap.
  3. #43 Re: HVAC Issue, Stuck on Defrost/Lower Only, Help
    Nov 2012
    Flint MI.
    Thanks for all the help Scotty. I'm going to chase down the line tonight after work.
    1997 GTP coupe,
  4. #44 Re: HVAC Issue, Stuck on Defrost/Lower Only, Help
    i was poking around under my hood today, and looked at the vac line from the sc, it hits the fire wall, then turns down the fender where it joins my washer pump line, then under the fuse box theres a T. one side went to the rad support to the vac ball. the other line off the T went into the wire harness that looks like it went into the cab through the firewall.
    so if you got a t and its broken, fix that sucker lol
  5. #45 Re: HVAC Issue, Stuck on Defrost/Lower Only, Help
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    i capped mine off today and closed the floor vent manually. now i have full strength air to forward vents only :-p
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  1. Lower Intake Stuck
    By green97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2017, 08:48 AM
  2. HVAC Blower, issue.
    By WolvesSoulZ in forum General Tech Discussion
    Last Post: 12-13-2012, 07:44 PM
  3. Defrost Issue
    By GreyGhost in forum General Tech Discussion
    Last Post: 12-27-2010, 10:35 PM
  4. HVAC Issue
    By mlasnoski in forum General Tech Discussion
    Last Post: 11-17-2010, 09:53 PM
  5. HVAC Wiring Issue
    By a3gtp in forum General Tech Discussion
    Last Post: 06-22-2010, 12:44 AM
