01 gp....Non supercharged 3800
I have never did this, but I did a few lower gaskets on 3100 engines. So I think I'll be fine.
I have found good info and write ups on it.
Mine is leaking right above the front valve cover and coolant sits in the little holes that the upper intake bolts go through. I initially thought it was the upper gasket but it doesn't seem to leak from there.
I will change the lower and upper gaskets, and elbows, even though I just changed them.
I take it the felpro metal gaskets or the ac delco metal gaskets are pretty much equal.
My only question is, is the upper intake reusable? If its not cracked or leaking? If its not reusable is there a particular one to get I'v seen a Dorman for 70.00 and a atp for $150.00 and a few in between.
