Thread: checking tranny fluid
Results 1 to 3 of 3
  1. #1 checking tranny fluid
    May 2012
    Cedar Rapids, Iowa
    Hey guys just a quick question on how to check the transmission fluid? (kinda dumb i know). But i was wondering if you just go out to the car when its cold and check it just like oil, or if it has to be warmed up to operating temp. I know some cars the car has to be on and some it has to be off. My car did not come with an owners manual otherwise i wouldve checked there.
    Thanks for the help
    chris
  2. #2 Re: checking tranny fluid
    Operating temperature.
    Car running.
    That's how I've always done it.
  3. #3 Re: checking tranny fluid
    Car has to running to check fluid level, you'd want it at or around operation temp.
    It helps to get it warm then while stopped, run through all the gears, P R N D 3 2 1, hold each there for 1 second, then go back through each to get back to park and check it. That way you can try and get a true reading after all the fluid has made its way through every part of the trans.
  1. Tranny fluid disappearing?
    By jokyfo in forum General Tech Discussion
    Last Post: 10-27-2010, 09:07 AM
  2. 98 GTP leaking tranny fluid
    By millfire517 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2009, 11:02 AM
  3. Leaking tranny fluid
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2009, 07:00 AM
  4. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  5. tranny fluid change ?
    By NEONNIGHT34609 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-19-2008, 09:48 AM
