Picked this up last month, cleaned the throttle body which was filthy, put a new MAF and fuel pump/fuel guage sender unit in and is running pretty good. Gets a little rough after it warms up and the tranny gets a little jercky. Think the cat is clogging up. It is not glowing red yet but it is radiating a lot of heat. Getting random cyclinder misfire CODE when really bad.
Here is the stalling issue. If I am tacking over 2000 rpm and rapidly take my foot off the accelerator the rpms will drop to zero and the car stalls. It doesn't happen every time, some times the motor will catch at about 600 rpm and pop back up to idle at 900rpm which is much better after the new MAF. If I let the gas off slowly it doesn't stall. It is like the idle circuit isn't kicking in fast enough to catch the motor before it dies. No error codes on this.
Anybody recognize this?
