Thread: Best replacement cv axles?
Results 1 to 9 of 9
  1. #1 Best replacement cv axles?
    Mar 2013
    St. Louis
    Hey everyone. New to the forum, just picked up a 98 GT. needs new half shafts and I've heard of some issues with different aftermarket replacements.
    Can anyone recommend a good replacement axle? Thanks in advance
  2. #2 Re: Best replacement cv axles?
    I run napa axles, as do many others, no complaints here.
  3. #3 Re: Best replacement cv axles?
    Mar 2013
    St. Louis
    Good. I've been looking at those. Question though, comparing the new and reman axles on the Napa website, the new axles show as being a little shorter than the reman. Is this an issue? Should I go with reman?
    Sent from my SPH-L710 using Tapatalk 2
  4. #4 Re: Best replacement cv axles?
    Nov 2011
    NY
    Used these... Happy with them!
    Halfshafts
  5. #5 Re: Best replacement cv axles?
    May 2008
    Schuyler, NE
    I wouldn't use anything but GM axles.
  6. #6 Re: Best replacement cv axles?
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    I have Autozone Duralast axles and they go out quickly.
  7. #7 Re: Best replacement cv axles?
    Virginia
    I have a 2003 GTP, 124K, was "vibrating" when car dips, went with Autozone over online, free replacements VS waiting for shipping and RMA numbers....Took a little under 2hrs a side, not just the shafts though since I was already knee deep...shafts, bearing hubs, calipers, pads, rotors...there's much on how to remove them, what worked best was after removing the calipers, caliper bracket, original hub nut was 36mm, (air wrench or cheater bar on end of 1/2 breaker bar) replacement was 33, finally got to ues my wheel puller i bought years back on the hubs, off in a jiffy, but for little extra room and less frustration at contorsionist positions....remove the top strut bolt,whack it out, losen the bottom, the knuckle will then move down (with a little gentle persuasion) enough for the spleen to come out clean....
  8. #8 Re: Best replacement cv axles?
    I'm cheap and run crap, but it's easy for me to swap and often parts are free.
    I'd suggest going with the best warranty for the best price. Probably Napa.
  9. #9 Re: Best replacement cv axles?
    Mar 2013
    St. Louis
    I ended up using napa reman. Replaced those and the hubs. Vibration is dramatically reduced, still slight but i know the engine mounts are shot
  1. Axles???
    By GRAND98 in forum General Tech Discussion
    Last Post: 07-13-2012, 09:10 PM
  2. What CV Axles to use
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2012, 04:49 PM
  3. Bad Axles?
    By lflylow in forum General Tech Discussion
    Last Post: 10-20-2011, 08:57 PM
  4. New CV Axles.
    By Brammer in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2011, 10:06 PM
  5. Don't buy these axles!!!!
    By 01RedfireGT in forum General Tech Discussion
    Last Post: 06-29-2009, 11:32 AM
