I think I have the lock issue and battery drain figured out on my wife's 08. All signs looking to be pointing at the BCM is starting to go bad. From reading it looks like the Lock Relay is built into the BCM unlike past years. I have a relay going bad that is not allowing us to lock the car. Searching this seems to be a issue with 08+ GM cars. I have found this same issue in most of the Chevy line.
What i can not find is a DIY on how to replace it. I know I have to get it reprogrammed when I get a new BCM.
I would like to first locate it and check over the pins and make sure everything is OK.
If I have to replace it can I start the car with the new BCM or does it have to be reprogrammed first? I all ready called the dealer and the cost to reprogram it is $125.
Thank you for any help on trying to get done on replacing it.
