I need to pull the trans to deliver to someone for an overhaul and install a cam in my car.
With this I was going to remove both item from the car. I would like to know if I should go about pulling from the top or dropping out of the bottom. Which is easier?
Yes I know i could remove the trans and do the cam with the engine in the car, no i do not chose that option
