Thread: Parts list for 99 Grand Prix N/A Header upgrade.
Results 1 to 12 of 12
  1. #1 Parts list for 99 Grand Prix N/A Header upgrade.
    Mar 2013
    ma
    My brother in law just picked this car up with 200,000 miles on it. Even up here in the north east this car is still in great over all shape with virtually no rust. So I told him if he wants to restore some stuff on it just let me know and I'll do the mods for free. No sooner the I said that, the flex pipe blew a giant hole in it.....which of course is how I ended up here, and why I'm now looking for information about header installs...
    So, I've decided on ether Speed Daddy or SSAC headers. Haven't decided yet to be honest. The only thing that scares me is how the flex pipe is attached to the header. I mean, did they really weld that thing on there???
    We live in ma and will need to pass emissions testing. So I'm looking for a parts list assuming everything needed. I plan to put a hi-flow cat in, do they usually come with the o2 bung, or will need to drill that out and place my own universal bung? I would hate to delete it, as he doesn't have the money for a tuner or anything to delete the codes with.
    Do these cars come with enough pipe to bolt right up to the cat-back, so that I can just cut out a section of the new pipe to place the high flow cat?
    From my understanding of reading this forum the past few days I need:
    -Header kit
    -2 3" band type exhaust clamps
    -2 2.25" band type exhaust clamps
    -fel-pro head gaskets
    -High-flow cat + clamps/adapter
    -RTV Gold
    Am I missing anything? Would you do anything differently? Were ordering tomorrow on somewhat short notice and the budget is between 3-400$.
    -Thanks
  2. #2 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    You don't need head gaskets. Headers come with everything to bolt them up to the catback.
  3. #3 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Why are you getting head gaskets? Headers come with gaskets, also rev isn't going to do anything but make a mess
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  4. #4 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    Ohio
    Reuse the stock manifold gaskets. The ones that come with the headers are crap
  5. #5 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Better Clamps are a suggestion!! And I don't know if my SD headers were mispacked or what, but I did not get the clamps for the cross over...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  6. #6 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    Mar 2013
    ma
    THanks for the info fellas.
    db what clamps did you use? I'm looking at these, it looks like I would need:
    Dynomax 33231 Dynomax Strap Band Clamps x2
    and
    Dynomax 33272 Dynomax Strap Band Clamps x2
    I think I'm going to have him just go catless for now and ignore the ses light until he needs to get an inspection. Then he can decide if he wants a sim+hollow cat or a $100 high flow Magnaflow w/o2 bung
  7. #7 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    Oct 2011
    Michigan
    Bill has a good write up on here with all the things you'll need
  8. #8 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Look at ZZP for a sim if you want, or just run the o2 sensor in with a spark plug non-fouler. But that looks like a good list minus the gaskets. Copper RTV is a good idea, and SSAC and Speeddaddy's are 100% identical just made by 2 different companies, and as far as we can tell there is no real quality difference.
    The only thing that may be missing off of that list is bolts from the rear most header piece to the exaust mine were melted into solid pieces, and the circle gasket from the rear most piece to the cat back, mine was not included with the headers.
  9. #9 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    Look at my writeup on installing headers.
    You don't need any RTV. I do nothing special to install headers and never have a leak from not using RTV.
    You don't need exhaust gaskets, the stock ones are mls and a quick wipe is all I've ever done to them. Again, never leaked.
    Move the firewall where I've instructed as the O2 on those two sets typically is in a bad locaton. Then work with the straight piece of pipe they give you to put the cat in the middle of it. Which likely means you need 2 additional 3" clamps.
    So I suggest either summit or Frozen Boost for the clamps. FB is typically the better cost.
    2 2.25" band clamps
    4 3.00" band clamps
    1 can brake cleaner on hand for the gaskets
    1 rag
    Jack
    18mm socket
    13mm socket
    Ratchet
    15mm socket
    That's about all you should need. Maybe some tools for the removal if things fight.
  10. #10 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    Oct 2011
    Michigan
    some ones ears were burning
  11. #11 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    Nov 2009
    Tennessee
    Bill hit on the clamps... That's it man!! Now it's just finding the headers..
  12. #12 Re: Parts list for 99 Grand Prix N/A Header upgrade.
    Oct 2011
    Michigan
    Don't waste your money get SSAC
  1. Grand Prix 04 Header Help
    By zachlepore in forum General Tech Discussion
    Last Post: 01-10-2012, 08:29 AM
  2. 2001 grand prix problem list
    By 01gt ryan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2010, 01:40 AM
