Thread: Moisture in the head/taillights
Results 1 to 20 of 24
  1. #1 Moisture in the head/taillights
    SE Level Member Ninjo's Avatar
    Houston, TX
    Ok I had this problem on my old GP GT.. HOW in the HECK to i fix this and what causes it... is it just a bad seal?! is it something i can fix w/o having to buy new parts?!
  2. #2 Re: Moisture in the head/taillights
    chicago
    use clear silicon and reseal it.
  3. #3 Re: Moisture in the head/taillights
    Feb 2008
    ^^^ That's pretty much it without getting new ones.
  4. #4 Re: Moisture in the head/taillights
    Jul 2008
    Poteau Oklahoma
    I pulled the plastic off the head light and cleaned the fog off of it this weekend, then used clear silicone to seal it back up. tons of patience and work, but it can be done if you take your time and dont force anything.
    as far as the tail lights..........I just pulled the plastic covers off and left them with the black louvers. patiecne is needed here as well.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  5. #5 Re: Moisture in the head/taillights
    Houston, TX
    Thanks again guys
  6. #6 Re: Moisture in the head/taillights
    Wausau, WI
    Quote Originally Posted by justwhisen View Post
    Have these held up and worked out the way that you had planned? Did you use clear silicone on the headlights and the taillights? Thanks........
  7. #7 Re: Moisture in the head/taillights
    quebec, canada
    so, the clear plastic on the tail lights can be removed from the rest of the assembly? i have had my tail lights off before, but had no luck getting them to dry out.
  8. #8 Re: Moisture in the head/taillights
    GT Level Member kjclawson's Avatar
    Fort Myers, Florida
    i had a inch of water splashing around in my marker light the other day.... so i would also like to know haha
  9. #9 Re: Moisture in the head/taillights
    Wausau, WI
    I have no idea, but it does say that they do or can come apart on the tails atleast......I still haven't touched mine.......I just have condensation in one though.......fwiw.
  10. #10 Re: Moisture in the head/taillights
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Old thread, I know, but has anyone got any updates for us? I have a relatively new OEM set of headlights and one has moisture on the inside of it after the rains we had over the weekend.
    I've heard of putting them in the oven to "bake" the adhesive off or to make it soft. Anyone try it?
  11. #11 Re: Moisture in the head/taillights
    DON'T SEAL YOUR LIGHTS, EVER!
    you must VENT the lights in order for them to not condensate. drill a small hole or two on the bottom of the lights and be done.
  12. #12 Re: Moisture in the head/taillights
    Minnesota
    this keeps em from getting moisture in em?
    a quick fix you can just pop the bulb out and use an air compressor and blow out the moisture
  13. #13 Re: Moisture in the head/taillights
    no, it doesnt stop the moisture, but it allows it to evaporate. when you seal them the moisture that gets in cannot get out. get the concept? youre going to get moisture in them regardless. the world hates people with nice things.
  14. #14 Re: Moisture in the head/taillights
    Minnesota
    oh ok yea that makes more sense, haha yea that is very true
  15. #15 Re: Moisture in the head/taillights
    Apr 2009
    I understand what you're saying, Bio, but I think there has to be a cause somewhere. Lenses aren't typically vented and don't usually have a problem that I've seen. There is a reason the one got fogged and the other didn't. Someone mentioned a bad seal around where the bulb goes in. I guess I'll look at this closer once the inside of the lense is dried out.
  16. #16 Re: Moisture in the head/taillights
  17. #17 Re: Moisture in the head/taillights
    Unless Im lost when I wetsanded and polished my crappy looking headlights last weekend their is a vent in the back of them mine had a grey cover that you can turn in the top corners. That cover didnt lead to anything and Id assume its a vent. X2 on not sealing ur head lights and I agree with BIO too the headlight bulb seal is 1st Id check.
  18. #18 Re: Moisture in the head/taillights
    Apr 2009
    Bio, are you saying you had moisture like this inside your headlights and drilling the hole fixed it?
    I put grease around the o-ring seal, hoping that would help and it didn't do a thing. If I wash it, then the driver side gets foggy inside. This past weekend, they both ended up with a little fog and they dried out naturally without me even opening them up, but it was really warm out. That tells me there's condensation inside the lense that makes it fog up when it gets cool and I'm spraying cold water on it, or new moisture is getting in when it gets wet. Either way, it's going to suck in the winter if I don't get it figured out.
  19. #19 Re: Moisture in the head/taillights
    i got lucky and once i bought new corners they were great.
  20. #20 Re: Moisture in the head/taillights
    Do what bio said and drill small holes in the bottom. As an extra step take the headlight and bake it for 15 @ 210* and press on the light in a pulsing action, this help the light reapply its adhesive correctly.
    Then bake in the sun to remove remaining condensation
  1. Water/Moisture on Inside of Tail light
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 05-22-2018, 10:11 PM
  2. Question on 98 GTP taillights
    By hunter_alexander in forum Visual/Body Modifications
    Last Post: 07-21-2008, 10:46 AM
  3. Painted my taillights
    By Boxman2k in forum Visual/Body Modifications
    Last Post: 05-13-2008, 09:51 AM
  4. Headlights and taillights!
    By Kyle73044 in forum General Tech Discussion
    Last Post: 03-24-2008, 09:14 PM
  5. Moisture in Headlights
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-19-2008, 01:39 AM
