Thread: Number 3 misfire
Results 1 to 20 of 27
  1. #1 Number 3 misfire
    new york
    i would put this in the same thread but i couldnt find it. but my 2001 pontiac grand prix gtp stock, it started a long time ago i went though the whole ignition system all good check compression good, it does it once and a great while right about oil change time i change oil and put a quart of mystery oil in and it goes away and runs smooth, could it be a sticking valve anyone have any ideas the dealers around here said i have to get the valves done anyone had this problem and if i gotta take the head off how hard is it to do??
  2. #2 Re: Number 3 misfire
    new york
    i got a crankshaft postion sensor going too would that affect the number 3 cylinder
  3. #3 Re: Number 3 misfire
    Is it always misfiring or does it quit after the oil change?
  4. #4 Re: Number 3 misfire
    new york
    it quits after i change the oil and put mystery oiil in
  5. #5 Re: Number 3 misfire
    new york
    but goes real good for while till about when i gotta do another oil change
  6. #6 Re: Number 3 misfire
    If you have a bad crank sensor yes it can cause misfires, a new one is cheep but one.
  7. #7 Re: Number 3 misfire
    Maybe a sticky lifter
  8. #8 Re: Number 3 misfire
    new york
    how do you resolve that?
  9. #9 Re: Number 3 misfire
    Could change out the lifters but that might not even be the problem.
  10. #10 Re: Number 3 misfire
    tennessee
    try a half can of seafoam in the crankcase about 500 miles before you change ur oil next could dislodge some gunk stopping up a lifter...
  11. #11 Re: Number 3 misfire
    new york
    i usally use a can in the intake also sorry i should of said that also
  12. #12 Re: Number 3 misfire
    tennessee
    thats good for cleaning the intake an valves etc... but just doing that doesnt get seafoam to the lifters to clean them hence putting it in ur crankcase aka where the oil goes
  13. #13 Re: Number 3 misfire
    new york
    so just put half a can in when i change my oil?
  14. #14 Re: Number 3 misfire
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by slick2500 View Post
    This*
    I had the same problem bad sensor replaced and no problems since
    Sent from my SGH-T989 using Tapatalk 2
  15. #15 Re: Number 3 misfire
    tennessee
    500 miles before not a garunteed fix but could help... try this^^ too
  16. #16 Re: Number 3 misfire
    new york
    got the new sensor today gonna put it in this weekend. how do you check to see if the lifter is sticking??
  17. #17 Re: Number 3 misfire
    tennessee
    there really isnt a check... you could take the valve covers off run the engine for a few seconds while watching the rockers to see if #3 isnt moving like the rest but that has the potential to be messy... just run the seafoam and if that doesnt work your only out $9 max, try the crank sensor... but im gonna lean more towards sticky lifter if it only shows up around oil changes...
  18. #18 Re: Number 3 misfire
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    you can use tranny fluid to wash a engine
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  19. #19 Re: Number 3 misfire
    new york
    i need to change the sensor bc its been acting up tach dropping to zero and stalling
  20. #20 Re: Number 3 misfire
    tennessee
    that little bit of info could have helped our diagnosis 100 fold... unless it just started to happen
  1. misfire on number 5 piston
    By sabercat in forum Introductions/Noob Questions
    Last Post: 11-21-2012, 03:52 PM
  2. number 3 misfire
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2011, 11:22 PM
  3. number 3 mifire help
    Last Post: 04-06-2011, 08:21 PM
  4. number 4 misfire
    By kawasakidrivinghick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2011, 03:13 PM
  5. car number?
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-31-2009, 11:36 AM
