Thread: Why does my car hate fog light relays?
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Why does my car hate fog light relays?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    If it's all corroded *again* and they keep dying maybe you need to consider moving the location of the relay to a drier spot. had the same problem with the OEM horns on the Suburban. They would work for a few months then one would get water in it and quit. Got tired of replacing them so finally remounted them up under the intake box behind the headlights instead of down behind the airdam. Just as loud, but drier....
    Option B be would be to cut the ends off a ziploc bag, wire through the ends, pull the baggie over the relay and tape the ends tight around the wires. Also di-electric grease the connections.
  2. #22 Re: Why does my car hate fog light relays?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    So I just installed my new relay and only my drivers side fog light works, any ideas on what can be wrong? Maybe bad relay?
  3. #23 Re: Why does my car hate fog light relays?
    Jul 2008
    Tampa, FL
    Solid connection to power? Solid connection to ground? Double check ballast plugs?
  4. #24 Re: Why does my car hate fog light relays?
    Nov 2012
    Madison
    swap the ballasts around maybe its hosed
  5. #25 Re: Why does my car hate fog light relays?
    Oct 2011
    huntley
    Yup all solid connections, I am going to switch the ballasts tomorrow. I will report back with the detalis
  1. '97 Engine Coolant Temp Sensor and Relays
    By Lscman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2012, 04:36 PM
  2. Same Relays - 8866
    By fakir in forum General Tech Discussion
    Last Post: 05-23-2012, 07:55 AM
  3. Can you hook up relays to stock bulbs?
    By szalajka05 in forum General Tech Discussion
    Last Post: 12-07-2011, 10:39 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Electrical Gurus step in (relays)
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2009, 10:30 AM
