Thread: Best fuel pump replacement
Results 1 to 14 of 14
  1. #1 Best fuel pump replacement
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Hey guys, I've been finally getting around to working on my car. So I decided I'd tackle my long cranking issue. Replaced the injectors, FPR, and fuel filter and it still persists, so I guess ill try a new fuel pump. I was told a long time ago by a mechanic that my pressure drops to 0 after you turn the car off, and that I had somewhat low pressure. So at work at my dealership, I can get an AC Delco replacement for 350$ with my employee discount. I was wondering what are the other options? There's this one at autozone for 100$ cheaper, but I want it to be reliable and not crap out on me. Airtex Master/Fuel Pump (E3973M) | 1998 Pontiac Grand Prix 6 Cylinders 1 3.8L SFI SC OHV | AutoZone.com
  2. #2 Re: Best fuel pump replacement
    Nov 2011
    Indiana
    anyone
  3. #3 Re: Best fuel pump replacement
    I would go with a ac delco I mean hell you probably got 10+ years out of the old one sounds like its worth another shot
    04 Comp G.
  4. #4 Re: Best fuel pump replacement
    Antioch, IL
    I have airtex for the past 10k miles, no problems yet
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Best fuel pump replacement
    Nov 2011
    Indiana
    Ill just go with the airtex then. Saves a hundred bucks
  6. #6 Re: Best fuel pump replacement
    We put napa pumps in at work, havent seen a problem with any thus far.
  7. #7 Re: Best fuel pump replacement
    Sep 2011
    Copperas Cove, TEXAS
    I have that Airtex, it has given me no problems yet.
  8. #8 Re: Best fuel pump replacement
    Jun 2012
    Salina, KS
    Run from Airtex.... It's playing russian roulette. Some have had luck with them but that is all it is... for every one person who has had luck I see probabaly 5 or 6 who have had nothing but problems (in my personal experiance). AC Delco is just a re-boxer anymore (Not genuine GM) so you don't know the actual manufacturer of the pump. Best bet its to find a Delphi. Delphi is the original OE manufaturer for GM on those particular pumps. NAPA carries them... should be around $300 to $350 walk in price depending on the market you are in.... Probabaly cheaper if purchased through your work's account. Just my two cents.
  9. #9 Re: Best fuel pump replacement
    GT Level Member sic6's Avatar
    san marcos, tx
    Just price one that has the best warranty.
    97 GTP
  10. #10 Re: Best fuel pump replacement
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    You can get the AC Delco #19180107 online at Rock Auto for $222.79. If you like the Airtex it's $166.79. I wouldn't have a problem with the Airtex but not at $250.00. BTW Delphi is $193.79.
  11. #11 Re: Best fuel pump replacement
    SE Level Member stealth06's Avatar
    Dec 2012
    New York
    I have used Airtex in my old Bonneville, and my work van (GMC Safari). Never had a problem with either one and the Safari has put on another 100,000 and is still going strong.
  12. #12 Re: Best fuel pump replacement
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    racetronix 255 pump prj performance
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  13. #13 Re: Best fuel pump replacement
    SE Level Member Reverant GTP's Avatar
    Iowa
    According to the airtex representative ive talked with when i worked at advance auto, they make ac delcos fuel pumps. Alot of ac delco parts are made by different manufacturers. For instance we used to get ngk and delco plugs with same markings all the time. I sold probably 10 fuel pumps a week for 3.5 years of those and only had a handful for warranty.
  14. #14 Re: Best fuel pump replacement
    Iowa
    As far as warranty goes bosch has lifetime and i dont recall ever having to warranty one out. However because of the higher price tag i sold maybe 1 or 2 a week of those.
  1. 2002 GP SE Fuel Pump/Sender Unit Replacement ????
    By skyjockey in forum General Tech Discussion
    Last Post: 05-30-2012, 07:13 AM
  2. fuel pump replacement
    By rcode in forum General Tech Discussion
    Last Post: 12-09-2011, 08:39 AM
  3. Fuel Pump Replacement?
    By swoollis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 06:14 AM
  4. Fuel pump replacement wtf?
    By mmschoch in forum General Tech Discussion
    Last Post: 04-21-2011, 11:41 AM
  5. Fuel Pump o-ring replacement
    By Sowhatsup2000 in forum General Tech Discussion
    Last Post: 04-07-2010, 04:16 PM
