Thread: gtp takes couple cranks to start
Results 1 to 8 of 8
  1. #1 gtp takes couple cranks to start
    SE Level Member Bigcat2020's Avatar
    Feb 2013
    Bryan
    i have a 97 gtp and im having problems with it starting. i have to turn the key to acessorie and off atleast 3 times before it starts up..if i jus crank it like normal it takes about 10seconds to start. i need ideas on what it could be ive changed the fuel filter, ran injector cleaner through it, ive done pretty much everything i can think of and ran out of ideas. i havent changed the fuel pump yet but ive changed the fuel pump resistor. im thinking it may be the pump jus seeing if you guys had any suggestions..thanks
  2. #2 Re: gtp takes couple cranks to start
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Check for correct fuel pressure, fuel pressure regulator. My car was acting the same way a few weeks ago but she's all good now after I got a new battery..so I suggest u go check battery, alternator, maybe even starter. Also check spark
    Sent from my SGH-T679 using Tapatalk 2
  3. #3 Re: gtp takes couple cranks to start
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    mine does the same. Depending on the weather n how long it sits, it cranks anywhere from 1-6 seconds. I changed injectors and the fuel pressure regulator. Next attempt is going to be a fuel pump since thats what a mechanic told me a looooong time ago when i first had starting problems 2 years ago.
  4. #4 Re: gtp takes couple cranks to start
    Feb 2013
    Bryan
    battery and alternator are fine. i have to do 3 cycles on and off(off than to accesorie) than on 4th crank it will start like a normal car. but if i jus get in it and go to start it takes about 10seconds to start. seems like its not getting enough fuel. im goin here soon to check the fuel pressure
  5. #5 Re: gtp takes couple cranks to start
    Sounds like the fuel pump
    04 Comp G.
  6. #6 Re: gtp takes couple cranks to start
    Feb 2013
    Bryan
    thats what im thinking. but i jus wanted to check to see if there was any other possibilities...thanks guys
  7. #7 Re: gtp takes couple cranks to start
    Quote Originally Posted by iRideGTP View Post
    These are all awful suggestions.
  8. #8 Re: gtp takes couple cranks to start
    Hook up a pressure gauge to the rail and see what it does.
    I'd say its a FPR before a pump.
  1. 2000 GTP cranks but will not start
    By darman1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2013, 01:46 PM
  2. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  3. Engine Cranks but Will not Start
    By rockytop104 in forum Introductions/Noob Questions
    Last Post: 10-04-2010, 08:21 PM
  4. cranks wont start
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2009, 08:10 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
