Thread: caliper rebuild
Results 1 to 8 of 8
  1. #1 caliper rebuild
    Feb 2010
    TN
    I want to powder coat a set of f-body calipers I am going to purchase a reman set. Since I have to take them apart to powder coat, and since they will be new can I resuse the seals and boots and all or once I take them apart must I buy new ones?
    Thanks guys
  2. #2 Re: caliper rebuild
    Feb 2010
    TN
    Wow, I stumped everybody?
  3. #3 Re: caliper rebuild
    you should just try to find used, cause im pretty sure if you take them apart you'll want to install new seals, looks very easy to rebuild too. you need a air compressor, thats it really.
    the dust boots can be reused for sure, the question really is will the seal take being taken apart then put back in? being that your are rebuilding them anyway, im back to used lol
  4. #4 Re: caliper rebuild
    Feb 2010
    TN
    Yeah thats what I was woried about can the seal take it but I can't find used anywhere cheap they want like 35. 00 and I can get reman raybestos or Wagner for 42.00 that's what I was looking at reman wait asec if the boots can be reused then I just need the seals and they should be cheap enough yep got a 40 gallon compressor so I am set
  5. #5 Re: caliper rebuild
    i'd break them down before buying new parts, being new, they may take it.
  6. #6 Re: caliper rebuild
    Jersey
    I rebuilt mine when i painted them. Rockauto sells rebuild kits seals and boots
  7. #7 Re: caliper rebuild
    Jersey
    I used an air compressor and wood to pop out the pistons
  8. #8 Re: caliper rebuild
    In auto mechanics class we used to rebuild calipers reusing the same rebuild kit time and time again and it looked ok.
  1. Caliper rebuild question
    By Logan541 in forum General Tech Discussion
    Last Post: 10-27-2012, 03:55 PM
  2. Need 13“ caliper rebuild kits but..
    By SDGTP99 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2012, 03:10 PM
  3. Caliper Paint
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 03:02 PM
  4. Best Caliper Paint?
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2010, 02:38 AM
  5. question on Fbody caliper pistons rebuild
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2008, 12:08 PM
