Thread: orfice tube location?
Results 1 to 7 of 7
  1. #1 orfice tube location?
    SE Level Member pontiacman22's Avatar
    Oct 2008
    Miami,FL
    Hey dudes. does any one happen to know where the orfice tube is on these things. if got a 98 GTP im redoin the whole a/c but i cant find the darn orfice tube. thanks
    Big John
  2. #2 Re: orfice tube location?
    Apr 2008
    Chillin at the Beach , VA
    I think in 98 it is furtherback than the 97, but on the drivers side under the airbox, you'll see the accumalator. Follow the line back towards the firewall and you'll see a fitting. Pretty big, so you shouldn't miss it. Unscrew that and seperate. the orfice tube will be inside the line closest to the firewall. Maybe a little tough to get out depending on when the last time it was changed. Had to use a pair of pliers on mine. Make sure there isn't any crap in the line before you put the new on in.
  3. #3 Re: orfice tube location?
    Feb 2008
    That's were I thought it was myself, just wasn't sure.
  4. #4 Re: orfice tube location?
    Oct 2008
    Miami,FL
    thanks dudes but i was lookin on the high side and i didnt find any fittings so i called up pines pontiac over here and they told me its on the high side were the line meets the firewall... im stoked to finish this thing man....oil pan gasket..motor mounts... and whole a/c system in 2 days + school hooorah!
  5. #5 Re: orfice tube location?
    Oct 2008
    Miami,FL
    lol i just reread you post and realized you said the exact same they did my bad bro lmao. sleep depervation is to blame
  6. #6 Re: orfice tube location?
    Apr 2008
    HAppy to see it's all coming together for you. I htought on the 98's they moved it further back, just didn't know how far back.
  7. #7 Re: orfice tube location?
    Oct 2008
    Miami,FL
    I got exited too quick i disconnected the fire wall lines and theres nothin in the pipes.... if i didnt live in hot south florida i would delete the whole system.
  1. Cut EGR tube from headers.
    By Lawngoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2008, 02:44 PM
  2. Oil Pickup tube
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2008, 02:18 PM
  3. pcm location
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-08-2008, 03:46 PM
  4. Modified Trans Dipstick tube from Intense...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-22-2008, 07:54 PM
