Thread: Acceleration Problem past 3500rpms
Results 1 to 13 of 13
  1. #1 Acceleration Problem past 3500rpms
    Jan 2013
    United States
    I’ve looked all through this forum and haven’t found a similar problem to the one I’m having.
    My car is a 2002 GP GT, mods include 3" downpipe, resonator, no mufflers, and a 9" open cone air filter.
    At in town speeds 0-40mph the vehicle behaves normal accelerating through the gears with equal appropriate acceleration. Accelerating to highway speeds 40-75 the car won’t rev past 4000rpms and all acceleration is lost after 3500rpms all while the RPMs continue to rise (but not exceeding 4000rpms) according to throttle position. In order to achieve highway speeds you have to feather the throttle, tricking the computer you want a different gear in order to achieve sufficient speed without high revs and the PCM killing sending fuel into the engine. You can floor it and the engine responds but will rev high without equal acceleration. If the throttle is left open allowing the engine to rev high for more than 15 seconds it will throw the "service engine soon" light on, but then goes off after you let off the throttle.
    I was thinking it could be a clogged Cat, the torque converter, abused transmission, or maybe the MAF is bad.
    Any insight into the issue would be much appreciated.
    Additional symptoms: Terrible gas mileage, and a loud sucking noise coming from my air filter during idle
  2. #2 Re: Acceleration Problem past 3500rpms
    If the check engine light came on, you have a code thrown. Figure out the code and then go from there.
    Sounds like it may be a misfire issue.
    You maybe also have a clogged cat.
  3. #3 Re: Acceleration Problem past 3500rpms
    Jan 2013
    United States
    I just replaced the Cat, lol.
    I'll take it to a shop and have them check the code. Thank you.
    Five Finger Death Punch, Woot Woot!!! Good band.
  4. #4 Re: Acceleration Problem past 3500rpms
    Jul 2012
    Chicago
    Check your coolant level. Have you fixed your UIM? Early on when mine failed it would drive around fine until you gave it the beans, then it would miss like crazy and not want to accelerate.
    -Carl
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I've seen an issue before where the icm was having issues supplying enough spark in the higher rpm range. If you have one to swap might be worth a shot.
    Edit... Now that I read it if im getting this right it sounds like a slipping trans. Probably a long shift max adapt code.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  6. #6 Re: Acceleration Problem past 3500rpms
    Jan 2013
    United States
    Quote Originally Posted by nos4blood70 View Post
    Coolant level is good. I haven’t fixed my UIM, any write up you could refer me to?
    Quote Originally Posted by rperry435 View Post
    The spark plug wires have been changed recently but the ICM might be the problem. I’m going to have it taken to my local shop and have the codes read to find out what’s up. The long shift occurs but never shifts to the next gear because the speed of the vehicle isn’t sufficient for the computer to initiate a shift.
    What about a vacuum leak?
  7. #7 Re: Acceleration Problem past 3500rpms
    Destroys cars izup69's Avatar
    Iowa
    Sounds like the trans is slipping to me. Maby the clutch disks are takeing a dump for 2nd gear. If you hammer on it from say 10mph in 1st gear dose it still slip at the 3500 rpm range. If not could be your 2nd gear disks worn out. Not enuf of them left to bite to. When you go to get on the highway at about 45-50 mph your car should kick into 3rd gear. If your going easy on it. From there you can give it just enuf gas to speed up without downshifting. It may be a pain to get on the highway but it will save what is left of your 2nd gear disks. For my car 3rd gear kicks in at about 90ish at WOT.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  8. #8 Re: Acceleration Problem past 3500rpms
    Jan 2013
    United States
    Quote Originally Posted by izup69 View Post
    It feels like a long shift, until I let off the gas it will shift. I tested it by physically shifting into 1st, 2nd, & 3rd gear and it exacted the same symptoms of high revs with no acceleration.
    I’m frustrated because I took it to Oreilly Auto Parts to see if they would read my engine code, but because the light isn’t actually on, they won’t read it. I need a place to start lol. I might just take it to a auto shop and have them do a full diagnostic on it.
    Could my fuel filter need replaced?
  9. #9 Re: Acceleration Problem past 3500rpms
    Jan 2013
    United States
    So my car threw a P0300 the other day. I can't decide what to replace first. I've got a list of stuff I can replace, Spark Plugs & Wires, Ignition Coils & ICM, Oxygen Sensors, Fuel Injectors, Exhaust Valves, Catalytic Converter (no point it's brand new), EGR valve, camshaft position sensor, or the worst case scenario my Computer is Defective!!! AH!!!
    Symptoms:
    If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
    Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
    Anyone had this code thrown and where did you start?
  10. #10 Re: Acceleration Problem past 3500rpms
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    spark load test, check for vac leaks, fuel pressure?
    DTC P0300
    Engine Misfire Detected
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  11. #11 Re: Acceleration Problem past 3500rpms
    Jan 2013
    United States
    Quote Originally Posted by Seachicken View Post
    DTC P0300
    Thank you, I might take the upper intake manifold off entirely just to check for cracks causing excess air into the engine. The thing that confuses me is, I'm getting terrible gas mileage, 10 - 12 miles per gallon and I'm driving her extremely gentle. if it's running lean why the terrible mileage?
    I also checked my transmission fluid and it is brown and burnt smelling, I'm concerned it's also a transmission problem.
  12. #12 Re: Acceleration Problem past 3500rpms
    Jan 2013
    Edmonton, Alberta
    if the pcm saw the car was lean it would probly try and "flood" the cylinders.
    take your tran pan off and change the filter, put dexVI back in too, then after 500miles drain the pan agian, and fill up agian, NO FLUSHING
    fix a known problem first
  13. #13 Re: Acceleration Problem past 3500rpms
    Jan 2013
    United States
    fix a know problem first
    Thank You. Gotta wait till payday to do it, lol.
  1. Vehicles you have or have owned in the past
    By IndeedSS in forum Off Topic Discussion
    Last Post: 04-07-2015, 08:53 AM
  2. a bit of work from the past few days
    By jakedidi in forum Visual/Body Modifications
    Last Post: 11-07-2010, 11:03 AM
  3. The past few months on GPF
    By Thunderturd in forum Off Topic Discussion
    Last Post: 01-09-2010, 07:03 PM
  4. curious if going past 14.7psi....
    By fst in forum Turbo
    Last Post: 09-15-2009, 11:51 AM
