Thread: E85 tune why? How?
Results 1 to 18 of 18
  1. #1 E85 tune why? How?
    SE Level Member Adam D's Avatar
    Jan 2013
    grand rapids mi
    So guys beat me down all you want for asking this. im sure it has been asked and answered a million times before but im using a app on amobile connection and the search function wont work for me. so i understand e85 has a higher octane rating but what are all the benefits disadvantages etc.. etc... if someone could just post a link to the post im sure already exists that would be greatly apreciated
  2. #2 Re: E85 tune why? How?
    advantages: ~104 octane (depends on mix available, changes), burns cooler (property of ethanol), cleans everything out, most of the time cheaper than gasoline.
    disadvantes: fuel economy drop (have to use ~30% more fuel), need to find stations where it's available.
    there isn't much to it, really.
  3. #3 Re: E85 tune why? How?
  4. #4 Re: E85 tune why? How?
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    I am going to be thread thief, but Adam D is also working on some of the same things I am considering, he just posted a WTB 1.9 rockers.
    I'm running a 3.4 pulley w/ intake, pulley, AL104s, 180* tstat and working on a tune. I know it's January and things will change some when it warms up outside. I've got a buddy helping me with the tune and right now I've cut timing to 12* and am still seeing 2* of KR on 91 octane, can't find 93 around here.
    So, buddy and I are discussing ways to get rid of that KR. He is trying to push me to buy injectors and run E85; I don't really want to run E85 due to being limited as to where I can buy fuel. I am considering looking for 1.9 rockers and going that direction instead; buddy says rockers basically reduce boost slightly there by allowing me to run more timing knock free.
    Any thoughts ladies and gentlemen?
  5. #5 Re: E85 tune why? How?
    you need headers ^^
  6. #6 Re: E85 tune why? How?
    Mar 2012
    Minnesota
    ****! I have headers also. That's what happens when you post in a thread while having a conversation.
  7. #7 Re: E85 tune why? How?
    What's your afr?
    Jan 2013
    grand rapids mi
    So this is not my intentions but does this mean hypothetically i could run a smaller pulley with less supporting mods to back it up? What is needed to run e85 tune and injectors
  9. #9 Re: E85 tune why? How?
    You can run a lot smaller pulley on e85 than 93
  10. #10 Re: E85 tune why? How?
    Mar 2012
    Minnesota
    What's your afr?
    I don't recall the numbers off the top of my head, but I know we went rich before pulling timing.
    Quote Originally Posted by Adam D View Post
    Depends on how far you want to go; but short answer yes. The advantages bio talks about all fight knock quite a bit. To run E85 you'll need bigger injectors so you don't run lean and depending on how small you're planning on going a bigger fuel pump.
  11. #11 Re: E85 tune why? How?
    Apr 2011
    Vassar, Mi
    If your still running a m90 most likely you don't need a bigger fuel pump yet, even on e85. If your pulling timing below stock to run a smaller pulley you need to run a bigger pulley. E85 rocks, drops egts a lot and has atleast 104 octane. Smaller pulley and more timing and all that's needed is bigger injectors and some tuning.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  12. #12 Re: E85 tune why? How?
    Mar 2012
    Minnesota
    My afr was 11.3.
  13. #13 Re: E85 tune why? How?
    May 2008
    Schuyler, NE
    A few years ago, my 01 had a 3.4 pulley, intake, and 3" catless DP. We have pretty ****ty fuel here in this part of Nebraska, so my timing was between 10-12 degrees at WOT. I switched to E85, and ran 19* timing without knock. Felt like a completely different car. Even went to as high as 26* without knock, but there's really no gain with that much timing, not to mention all the extra stress it causes.
  14. #14 Re: E85 tune why? How?
    May 2012
    Where winter never ends
    I am currently running headers, intake, 60lbs injectors, 3.2 @ 21* of timing with 0KR. E85 is the best thing in the world if you can get your hands on it.
    Pros: Its ethanol and it works on the same premise of putting rubbing alcohol on your hand and blowing on it. (It gets really cold due to the highish flashover). It cools the cylinder walls as it enters removing KR due to high temps. I have been running E85 for a year now and I will never go back to normal gas.
    Cons: As said before, you do lose 30% fuel economy. Also if you live in a cold climate. very cold weather can sometimes cause really hard starts. It was -7 here (-35 after windchill) and I had to crank it three times and let it sit for a good while before driving away. The reason being ethanol does not vaporize at that cold of a temp. So the engine has to ignite the 15-30% gas to warm the cylinders so allow the ethanol to vaporize and explode. It really isnt a massive issue, just have to crank a few times.
    What do you need to run E85? 60Lbs injectors for starters due to the 30% more fuel. Headers due to the 30% more fuel. A tuner. I tuned mine my self with HP tuners, If you plan on switching I greatly recommend on learning your self. Makes life much easier when you switch pulleys or something. You will also need a Wideband. DO NOT GO WITH OUT THIS YOU WILL BREAK LOTS OF THINGS WITH OUT IT.
    2000 Regal - Winter Beater
    Jan 2013
    grand rapids mi
    Wideband?
  16. #16 Re: E85 tune why? How?
    May 2012
    AEM - AEM Wideband O2 Sensor #AEM-30-4100
    Tells you the AFR.
    EDIT: I just use the Digital Gasoline one and shoot for 14.7 when tuning because 14.7 is a lambda value of 1, therefore there is no point is getting one just for e85.
    Jan 2013
    grand rapids mi
    God da** i neer more money lol all i wanna do is throw all my money in this. So much ish to do.
  18. #18 Re: E85 tune why? How?
    May 2012
    So worth it though. I spent about 1k on everything I think (Split hp tuners 3 ways with three friends)
  1. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  2. PRJ Tune
    By 2001GTP in forum PCM Tuning
    Last Post: 04-15-2010, 08:06 AM
  3. Who can tune?
    By Bedwards in forum PCM Tuning
    Last Post: 03-28-2010, 01:07 PM
  4. tune?
    By RICE KILLER in forum PCM Tuning
    Last Post: 03-10-2010, 04:00 PM
  5. tune
    By tihosick in forum Northeast
    Last Post: 09-08-2009, 10:08 PM
