Thread: Windshield Washer not working
Results 1 to 4 of 4
  1. #1 Windshield Washer not working
    SE Level Member trailshredder's Avatar
    Feb 2009
    Central Ohio
    Bad time of the year for my squirters to quit, but here it is! I took my wheel liner down, pulled the plug and put a volt meter on and determined it isn't getting any power when I hit the switch, so I am leaning toward a good pump. When I hit the switch though, the wipers take off and do 4 or 5 swipes, so that tells me the switch is good too. Any suggestions?
    02 Grand Prix GT, Silver with all options.
  2. #2 Re: Windshield Washer not working
    Omaha, NE
    I hate it when my squirters don't squirt!
    If its not getting power, check for a ground issue.
  3. #3 Re: Windshield Washer not working
    If you do not get any power at the plug then a new pump wont fix it, it could be the switch still. And those are not the easiest thing to replace.
  4. #4 Re: Windshield Washer not working
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    When I bought my 03 GTP, the wipers didn't squirt. When I checked the pump, the housing was actually broken (F'N PO). With mine, the wire harness tested good at the pump. Bought a new pump from Advanced Auto and still didn't work...Started testing wiring and switches all over, finally tested the new pump w/ batteries out of the car. The new pump was bad, so returned it and got one from AutoZone, and all good since.
    Six monthes later, the wiper motor went out--which is not as easy to get to, take apart, or put back together. Anyway, after weeks of screwing w/ it off and on, turns out the wiper motor was good all along, it was a bad ground (engine compartment near bottom of driver wheel well--for wiper motor--I believe (?) pump has different ground).
    The point you care about is, IIRC, (I'm quite sure) the wiper motor and the washer pump are wired separately, ie the wiper motor can work fine even when the washer pump is broken/bad wiring, and vice versa.
    The new washer pump was <$15, if you have good power at the pump (and/or test pump w/ battery) and it doesn't squirt then its a bad pump (or possibly clogged line), if you dont have power at harness at pump, then its either bad wiring (double check ground) or bad switch (which costs so much I was about to just add a separate switch and wiring for the pump).
    Good luck.
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  1. Windshield washer pump?
    By MNGPGT in forum General Grand Prix Discussion
    Last Post: 12-13-2012, 10:13 PM
  2. Windshield washer nozzle???
    By mick777wauchope in forum General Tech Discussion
    Last Post: 04-16-2012, 03:06 PM
  3. Windshield washer fluid
    By flyboyray1 in forum General Tech Discussion
    Last Post: 03-18-2010, 10:07 PM
  4. Windshield Washer Fluid
    By Pontiac99GTP in forum General Tech Discussion
    Last Post: 09-09-2009, 01:35 AM
  5. Windshield Washer not Working
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 06-02-2009, 06:08 PM
