Okay I have a 97 Grand Prix Gt and use a OBD2 scanner on it and it reads P0171 System Too Lean Bank. And I don't know what it mean system too lean bank 1 is that a o2 sensor not working anymore or what.
Hi there, I moved your thread to an area where it should get better exposure. The forum suggestion area isn't a high traffic section for engine issues. Should get more visibility here.
On P0171, if you google the code or do a search here (search is dead center at the top of the screen and al little tough to see) on that code and my screen name. You can find a ton of information. The issue is almost never the sensor.
check out my threads on this code lots of info
Erik everytime I turn off the engine I hear a ssss or a like there's air escaping somewhere.
do you have the stock air box on the car
Yes I do.
mine did that before i changed the lim gaskets you most likely have a vacuum leak somewhere. i would replace all the vacuum lines and check the egr tube at the intake and the exhaust manifold. also use your scanner to check you iac and ltft
What is the egr and ica and the ltft? Where is the lim gaskets? Where are all the vaccum lines? I'll have a hard time doing all this cause its freezing here in wisconsin.
I hear ya when you say its freezing in Wisconsin. lol. I don't really know where all those are located myself but if you have the car idling and spray MAF cleaner or ether around the engine bay and the car revs up you know you have a vac leak. Also where in Wisconsin are you located?
I use a little propane to check for leaks. Could be more dangerous in some ways, but I hate spraying flammable liquids around the engine.
Agreed. Wisconsin has been bitter cold lately.
I am in Brown Deer, What about you? What do you clean the MAF with?
Oh sweet its not that far. Oh okay my car has to go back to the tranny shop tomorrow to get scanned for the stupid P1870 code which is toqure converter clutch is slipping but I don't feel that it is slipping.
