Thread: methanol injection !
Results 1 to 10 of 10
  1. #1 methanol injection !
    SE Level Member 2000supercharged's Avatar
    Aug 2012
    unitedstates
    okay i have a chance to do methanol injection on my car. what are peoples thoughts? it would be a whole snow methanol injection kit with tubes resivour and pump for a 100 Bucks. so what are peoples thoughts ? waste of time ? is it worth it ? im going to be pushing pace setter headers and CAI and exhaust and a 3.4 pulley so ? i know it would help lower intake temps but just talking to some other grandprix owners.
  2. #2 Re: methanol injection !
    you should do a little searching around, it's a topic that comes up every couple months since the site started.
    i'm one of the main contributors to that.
  3. #3 Re: methanol injection !
    Thanks, Eastwood.
  4. #4 Re: methanol injection !
    May 2008
    Schuyler, NE
    It seems to work well at eliminating small amounts of kr and dropping .1-.2" in pulley size when spraying through a TB spacer. Issues can arise when you try to push it harder than that.
  5. #5 Re: methanol injection !
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    for a hundred bucks? Buy it. Been running it for a while. Has worked well on my setup.
  6. #6 Re: methanol injection !
    Aug 2012
    unitedstates
    well people have different thoughts but i wouldnt assume how it wouldnt do alot since its supercharged?
  7. #7 Re: methanol injection !
    it helps in small doses, but when you start spraying too much it ends up just causing more issues than good.
  8. #8 Re: methanol injection !
    Jul 2011
    CT
    What is a "small dose" ? I use a 7gph nozzle and it has always kept kr to an absolute minimum on 93 octane, 18* advance and a 2.6 pulley.
    For the op's setup i would say a 4 or 5gph nozzle would be the most he should run.
    BUT if you are running a gen III, i would avoid the meth injection due to the fact that the water/meth will just destroy the ****ty coating on the blower rotors.
  9. #9 Re: methanol injection !
    GTP Level Member joshv's Avatar
    canada
    has been working well for me, no issues- im using cartunings kit
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  10. #10 Re: methanol injection !
    i ran a 5GPH nozzle and i didn't run enough timing to make good use of it so the car always felt boggy and slow.
    did let me run smaller pulleys, though.
  1. Methanol Injection On near stock gtp?
    By dert in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2011, 12:20 AM
  2. Methanol Injection ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-01-2010, 08:28 PM
  3. methanol injection questions
    By blessed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2009, 11:15 AM
  4. Methanol/water injection
    By gtp59 in forum General Tech Discussion
    Last Post: 04-01-2009, 09:59 PM
