Thread: Thermostat
Results 1 to 9 of 9
  1. #1 Thermostat
    SE Level Member keenan00gtp's Avatar
    Oct 2008
    Iowa
    what does a 180* thermostat do when compared with stock thermostat? Pros/ cons?
  2. #2 Re: Thermostat
    Jul 2008
    Germantown, Maryland
  3. #3 Re: Thermostat
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    ^^^ those are pretty neat.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  4. #4 Re: Thermostat
    Feb 2008
    Quote Originally Posted by Quicklynx View Post
    I've done a little research on these balanced thermostats and didn't find one available for our engine. Does anybody know if a balanced thermostat exists for us?
  5. #5 Re: Thermostat
    Donating Users
    W-S, NC
    Quote Originally Posted by keenan00gtp View Post
    A 180* stat will open when the coolant reaches 180*, where as the stock is set @ 195*. A 180* will help your GP to run cooler as long as you have air flow. If you run a 180* stat with a stock pcm, youll notice it will run hotter. You'll either need a reprogrammed pcm or a manual fan-turn on switch to take full advantage of it. The downside of a 180* stat is you will lose some mgp's, but not a lot. Im personaly running a 180* myself along with a manual fan switch.
  6. #6 Re: Thermostat
    Jul 2008
    yea you'l def want a tune, my gas mileage was awful but after Josh and I reset the fans, and did some tuning my gas mileage is moving up again.... thank god!
  7. #7 Re: Thermostat
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    I didn't notice a drop in MPG's with my 180* stat and that was before I had put in my ZZP pcm with reprogrammed fan turn on points.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  8. #8 Re: Thermostat
    Oklahoma
    Quote Originally Posted by Blown97 View Post
    I dont remember where I found it, but I had found a balanced thermostat for GM vehicles before. It looked like one for our cars but I dont remember the details on it now.
  9. #9 Re: Thermostat
    Feb 2008
    Yeah I remember only seeing one for the old grand prixs with the older 3.8l which doesn't take the same thermo as the 3800. I would like one, I hope they do exist for us cause they are the shizzz nit!!
  1. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  2. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
  3. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
