Thread: Where to start modding my GTP
Results 1 to 20 of 27
  1. #1 Where to start modding my GTP
    Banned
    Jan 2013
    Colorado
    First I totally read the sticky on where to begin modding a grand prix. And I plan on doing basically the first things suggested. I'm doing everything in the zzp stage 2 kit. That's not really where I had issues. The kit comes with a new downpipe. Now from there should I get that power log manifold or just a full header? Also I wanted to get cams for my car. Can I get cams (along with the valves and other things etc) to accompany the stage 2 kit mods or did I need other stuff? Then I wanted to get an electric water pump too. Would I need any tuning or anything like that with an electric water pump? And if I do the cams, stage two kit, electric water pump would I need to upgrade the intercooler too?
  2. #2 Re: Where to start modding my GTP
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    Here a thread i think you should read if you want to start modding your GTP.
    http://www.grandprixforums.net/safel...0-a-67580.html
    2007 Pontiac Grand Prix Base - Sold
    2007 Chrysler Aspen 4.7 - Current Car/Family SUV
  3. #3 Re: Where to start modding my GTP
    Banned
    Jan 2013
    Colorado
    I said I read that thread. These are questions I have after reading that thread. Also what should I do for the transmission?
    Headers > Plog any day of the week.
    Avoid the stage kits stuff can't be purchased from other places or separate.
    Drpends what can you go with will decide what needs to be done. A VS can can be installed without any additional tuning (although always recommend) all the other cams require a tune. You still should change out your valve springs, timing chain with whichever cam you decide to go with.
    Our cars don't have a Intercooler..but depended on how far you won't to mod you can always add one..
    Search bars at the top of the page..you gotta do some research
    04 Comp G.
  5. #5 Re: Where to start modding my GTP
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    buy a new corvette
  6. #6 Re: Where to start modding my GTP
    Banned
    Jan 2013
    Colorado
    I did as much research as I could find. They have a heat exchanger right? If I buy headers that would usually include the downpipe right to eliminate that u-bend?
    No heat exchanger stock. You have one of those when its intercooled. Yes it includes the downpipe and deletes the ubend. 04+ don't have ubends stock. 97-03 so do.
    04 Comp G.
  8. #8 Re: Where to start modding my GTP
    Cam single. Buy headers don't waste money on the stage kit.
  9. #9 Re: Where to start modding my GTP
    Banned
    Jan 2013
    Colorado
    At what point would I need to put a heat exchanger in? Like how much power? And I wasn't necessarily getting the stage kit but at least all the things from the stage kit.
  10. #10 Re: Where to start modding my GTP
    You don't ever "need" it. Its a want thing more than anything.
    This. Depends on how much power your wanting to make. Keep in mind are transmissions are already pretty ****ty from the factory. Adding more power can just put not wear and tear on them. Plan on getting a built one if u go all out.
    04 Comp G.
  12. #12 Re: Where to start modding my GTP
    Banned
    Jan 2013
    Colorado
    Yeah I was thinking of a transmission rebuild kit too. Around how much power before I should add a heat exchanger or trans cooler?
    Heat exchangers has to deal with intercooling so you won't being with that right now
    Some blow there tranny in stock power level so its luck if the draw and depends in how you treat car and drive it. If your constantly putting your foot down don't be surprised if it blows quick. If your driving it normal you should be already but again nobody can tell you when it's going to F up.
    04 Comp G.
  14. #14 Re: Where to start modding my GTP
    Banned
    Jan 2013
    Colorado
    Um not exactly sure what you meant in those answers. I was talking a heat exchanger for the engine coolant then a trans cooler to help out the transmission. I just want to do all the preventive maintenance I can on the transmission.
  15. #15 Re: Where to start modding my GTP
    Your talking about a radiator? You'll never need anything other than a stock one. Trans can last a long time i'm still on my stock one at 229K miles.
  16. #16 Re: Where to start modding my GTP
    Banned
    Jan 2013
    Colorado
    Thank you!!! As for the trans I still wanna beef it up as much as I can to prevent anything. Especially if I'm putting down more power to it.
  17. #17 Re: Where to start modding my GTP
    I have a spare laying in the garage so if mine goes out I'll just swap it out but if you don't want down time on your car you can get a rebuild with a 300m input shaft hardened 4th gear and 7/8th chain. You'll be good for a good while then.
    Oh radiator gotcha you like Dsmuts said you won't need need one of those unless your happens to crack or something.
    04 Comp G.
    Tripleedgeperformance is the guy to go to for trannys
    04 Comp G.
  20. #20 Re: Where to start modding my GTP
    Banned
    Jan 2013
    Colorado
    I wasn't trying to buy a whole new tranny yet. Are there specific things that are known to go bad on these transmissions?
  1. New member ready to start modding!!!
    By jayroca in forum Introductions/Noob Questions
    Last Post: 01-23-2013, 06:29 PM
  2. DIY CAI and modding help please!
    By Ryan71695 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2012, 05:35 PM
  3. Modding 08 GP GT..
    By 08GrandPrixV6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2009, 09:57 PM
  4. Time to start modding?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2009, 12:55 PM
  5. 04 gtp comp g where to start with modding??
    By justin98 in forum General Tech Discussion
    Last Post: 03-21-2009, 11:50 PM
