Thread: Question on valve spring
Results 1 to 19 of 19
  1. #1 Question on valve spring
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    I plan on doing a cam swap here on the spring, but i'm ready to top swap next week. So I was woundering if I can swap( while the heads are off) and run 105s safely until I do the cam swap in the spring.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: Question on valve spring
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Why are the heads off? I would imagine you could run the heavier springs, but I do not know if the stock cam shaft is hardened enough to withstand the extra force. If you do change the springs you should change the chain the same time. The old chain will fail under the extra force. Why do you want to change the springs now? You'll need to take everything apart again to do the cam I would just wait till then.
    97 Bonneville SE Not so much a 97 anymore
    he's doing a top swap which requires him to use L67/L32 heads.
    04 Comp G.
  4. #4 Re: Question on valve spring
    Jul 2011
    Michigan
    I am top swapping so the heads are already off. I was thinking of throwing the springs on now while the heads are off, that way when im ready for my cam swap I don't have to take the heads off again, or pressurize the cylinder while i change the springs.
  5. #5 Re: Question on valve spring
    Apr 2011
    Vassar, Mi
    Why don't you just hold off until you can do the top swap and the cam at the same time? Seems pointless to do the same work twice for no reason...
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
    I think you'll be fine going ahead and putting the springs in it might but a bit more wear and tear on the valve train but you'll probably be replacing the timing chain and dampener. Ill let others chime in though!
    04 Comp G.
    Quote Originally Posted by Anthony Smith View Post
    You don't have to pull the heads to do a cam.....
    04 Comp G.
  8. #8 Re: Question on valve spring
    Texas
    Valve springs will be easier to swap with the heads off I say go for it.
    85 Corvette
    01 TA
    03 Z06
    Plus if you drop a valve like I did when I did my springs you'll have to pull the head anyway and rear was a pain to do valve sprigs in with the motor in the car.
    04 Comp G.
  10. #10 Re: Question on valve spring
    Apr 2011
    Vassar, Mi
    Ok....but you still have to pull the fuel rail, injectors, valve covers, rockers, push rods, supercharger, lower intake and lifters so.....why would you do all the work twice? Be patient, build it all at once and be done.
    Those things are pretty simple to pull doesn't take whole lot of time or effort. He's having to remove his heads now anyways to top swap why wouldn't he just take the extra and go ahead and do his valve springs why he's at it?
    04 Comp G.
  12. #12 Re: Question on valve spring
    105 springs are some of the easier on valve train springs that we have available. I would put them on w/o worries.
    On the work invoved for a cam swap... I disagree, all the time of putting in a camshaft is getting the lifters out. If we didn't have to pull the lifters, it would take an hour or two for a cam swap at the most.
    Lower cradle 20 min (including draining coolant and supporting car)
    Pull timing cover 10 min
    Remove chain and thrust plate 5 min
    Slide cam out. 5 min
    As for dropping a valve into the motor, if you have the intake off, you don't usually have to pull the head. The right sized magnet and a zip tie have been some of the worlds best tools on a bad day for me. Another trick is if you don't have air to hold the valves closed, ensure you've rotated the engine to have the piston up on the cylinder you are working on. Valve can't go far if the piston is at the top of the stroke.
  13. #13 Re: Question on valve spring
    And God of the 3800 has spoken!
    04 Comp G.
  14. #14 Re: Question on valve spring
    I'll never do another cam swap at a guys house where there's no power. String trick didn't work so well for holding the valve in question up.
  15. #15 Re: Question on valve spring
    Lol the magnet trick didn't work for me so I just pulled the heads and recently dropped them off to the machine shop and ill have him check them before I throw them back on. Never will I do another cam swap in my driveway lol
    04 Comp G.
  16. #16 Re: Question on valve spring
    Nov 2009
    Central Jersey
    So at the end of the day black with this you can do whatever your heart desires. For what it is worth doing valve springs with the engine in the car isn't a huge deal as long as you can fill the cylinder with air or bring the piston TDC.
    I think everyone's forgetting the part where he is doing a top swap that's why the heads need to be pulled off so why not make it easier for himself just in case he doesn't have a decent sized air compressor to do the valve while they're still on the car. Plus he's having to change the head gasket anyways just save yourself the time (when you do the cam) and go ahead and deal with heads all at once and valve springs are a lot easier to do with the heads off then on especially the rear)
    04 Comp G.
  18. #18 Re: Question on valve spring
    Jul 2011
    Michigan
    ^^^ Heard that lol. Thanks bill, always appreciate your words of wisdom. But i may just wait for the cam swap becuase i don't want to buy the supercharger and LIM Gasket Twice. ( or can i reuse them if they are that new?)
    Reuse the lim gasket. Replace the SC gasket that's like $8 or so from Zzp last time I checked. If it was me and I could afford some downtown with the car I would do the cam swap with the top swap and be done taking the car apart.
    04 Comp G.
  1. Valve spring install
    By apierce1289 in forum General Tech Discussion
    Last Post: 05-11-2012, 12:48 PM
  2. Valve spring compressor
    By apierce1289 in forum General Grand Prix Discussion
    Last Post: 05-04-2012, 04:26 PM
  3. ls1 valve spring comprssor
    By mskram1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2012, 11:39 PM
  4. Valve spring retainers for S1X cam?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2011, 05:27 AM
  5. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
