Thread: Small air space in coolant reservoir
Results 1 to 17 of 17
  1. #1 Small air space in coolant reservoir
    Oct 2012
    USA
    I had a curious observation about coolant reservoir in my 05 grand prix base. I think the hose from the radiator filler neck to the reservoir should be airtight. So when the car heat up or cools down, coolant can be pushed out of sucked in to the radiator.
    It is strange to me why the coolant reservoir has a U-shaped structure (as the red line shows) where the hose enters the reservoir. And the hose does not connect to the bottom of the reservoir. If the whole cooling system is airtight the short column where the hose enter the reservoir should be full of coolant. The cold mark on the larger side of reservoir is lower than the small column. So when it is cold, there is a tendency that coolant will flow from the small column to the larger side. The only reason that it does not flow to the larger side is because the cooling system is completely airtight so it can maintain this uneven level. This is a strange design to me. If the hose just connect to the bottom of the reservoir, will it be better? This way, we are not artificially create a tendency to draw something in.
    As I circled in yellow line in the attached picture, this space is above the entrance of hose to reservoir and I always find a small air bubble here. I lean the reservoir and let the air bubble out, but it will appear again. I am confused where this air comes from. Maybe it is because I did not completely purge the air out when I flush the system so the small air bubbles walks its way out and end up being in this high place. It has been almost two month since I flush the cooling system and all the air bubbles should already walked its way out.
    Any idea why I always see the small bubbles there? The coolant rise and fall as the car heat up and cool down normally.$(KGrHqZ,!hgFCF2BSE0vBQtSO-PfNg~~60_1.JPG
  2. #2 Re: Small air space in coolant reservoir
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Ever used a bottle of Sta-bil? same basic reason, you'd want the amount of coolant in the tank not to effect the pressure against the cap.
  3. #3 Re: Small air space in coolant reservoir
    Oct 2012
    USA
    Quote Originally Posted by addzradd View Post
    Thanks! Would you please explain it a little bit more? It seems to me the difference in liquid level between the two sides will influence the pressure against the cap.
    For the sta-bil bottle, I guess the bottle of is designed for the convenience of measuring and pouring a certain amount of liquid.
  4. #4 Re: Small air space in coolant reservoir
    Pennsylvania, USA
    The level will be lowest when cold, and it should be above the opening from that u-bend. It's like that to create a vacuum and to help keep your cooling system at the correct pressure. That plus the radiator cap.
    Overfilling the reservoir won't damage your engine, at worst it overflows out the overflow opening on the back of the reservoir. But under filling it can if it causes air to be introduced into the cooling system.
  5. #5 Re: Small air space in coolant reservoir
    Oct 2012
    USA
    Quote Originally Posted by nik12937 View Post
    Thank you! I understand that. The cold mark is above the U-bend so when the engine is cold, the radiator suck in coolant, not air. What I don't understand is why they design the shape like U-bend. They could easily put the hose on the bottom of the reservoir or sidewall that below the cold mark. That way, they can still prevent air coming into the radiator.
    Also, I always find a small air bubble in the yellow circled area. The bubble will come back after I get it out of there by leaning the reservoir a bit and drive for a while. Do you have any idea how this air bubble get there?
    I live here. DirtDog's Avatar
    Jun 2012
    It could get there by the slightest amount of air being in the system and getting worked out
    Sent from my DROID RAZR using Tapatalk 2
  7. #7 Re: Small air space in coolant reservoir
    HUDSON
    "If the hose just connect to the bottom of the reservoir, will it be better?"
    If the overflow hose from the radiator was positioned at the very bottom of the overflow tank, any "crud" (dirt, corrosion, gloop) that settles out from the coolant will find it's way back into the radiator, and could possibly clog the overflow bottle hole/hose.
  8. #8 Re: Small air space in coolant reservoir
    Jun 2012
    i would change the location of that hole. it would make a difference but why change it when its not causing any problem?
  9. #9 Re: Small air space in coolant reservoir
    Oct 2012
    USA
    Quote Originally Posted by marines542 View Post
    I get the cooling system flushed two month ago. Maybe some small air bubbles gradually walk their way out.
    So do you think if the system is completely out of any air bubbles, the yellow circled space should be full of coolant and no air should appear?
  10. #10 Re: Small air space in coolant reservoir
    Oct 2012
    USA
    Quote Originally Posted by QUICKSILVER462 View Post
    Good point. This totally make sense. I do notice there are some dirt precipitate on the bottom of the bottle. So Putting it sideway instead of bottom can avoid this problem.
    But what is the purpose of making a U bend instead of just having the hose connect to the side wall? Hope you have another genius explanation
  11. #11 Re: Small air space in coolant reservoir
    Oct 2012
    USA
    Hmmm...I was just curious why they design a shape like this. Isn't it a little easier to just make it a bottle and put the hose on the side wall? It seems to me that it makes it more complicated to make a U bend if the U bend does not give any benefits.
  12. #12 Re: Small air space in coolant reservoir
    Jun 2012
    sorry i meant would not change the position of the hole unless your having some sort of problem
    its amazing what a small typo will do
  13. #13 Re: Small air space in coolant reservoir
    Oct 2012
    USA
    I see. i am not going to change or modify the reservoir. I am just curious about the logic behind this design.
  14. #14 Re: Small air space in coolant reservoir
    Jun 2012
    Quote Originally Posted by Coldwaves View Post
    well there didnt have to be any logic...just that some jack as* that makes way to much da*n money was like this is the most efficient designa you should use this. Then another over paid dumb as* gets paid way to much to agree with the jack as* and so thats how the design is put into use in the car
  15. #15 Re: Small air space in coolant reservoir
    Oct 2012
    USA
    I still keep getting air in that yellow circled area. Every time I saw small air column there, I get it out. But the the air keeps coming back. It seems the air only comes back when the car cools down and then being driven for a while. The car does not overheat or do anything wrong. Oil and oil filler cap look good. No sign of moisture. No performance issue either. I am so confused how the air comes there. Maybe there are still little bit of air trapped in the cooling system and walking out itself?
    Jun 2012
    Yea there could be. If I were u I wouldn't worry about it unless u start loosing coolant
  17. #17 Re: Small air space in coolant reservoir
    Oct 2012
    USA
    I fill the coolant to the cold line when the car sit overnight last week. The coolant level hasn't changed much yet. It is a little over the coolant line now since the weather is much warmer this week. I will keep watching it.
    I have tried get the air out of the yellow circled space maybe 10 times (Maybe total 100 or so air space) and I am amazed how much air can be trapped in the cooling system after a flush. I will keep purging the air out of the reservoir and see whether I can get all the air out and the air stops coming back to the yellow circled area.
  1. Coolant reservoir
    By TheManInBlack in forum Shops and Community Heroes
    Last Post: 12-31-2011, 02:50 PM
  2. Gray liquid in coolant reservoir on 97 gtp
    By SteveCZ28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:47 PM
  3. Coolant Reservoir Tube?
    By Pagss in forum General Tech Discussion
    Last Post: 10-19-2010, 01:49 PM
  4. Total new system,, small space 2005 supercharged
    By scoobyydooooooo in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 10:27 PM
