I had a curious observation about coolant reservoir in my 05 grand prix base. I think the hose from the radiator filler neck to the reservoir should be airtight. So when the car heat up or cools down, coolant can be pushed out of sucked in to the radiator.
It is strange to me why the coolant reservoir has a U-shaped structure (as the red line shows) where the hose enters the reservoir. And the hose does not connect to the bottom of the reservoir. If the whole cooling system is airtight the short column where the hose enter the reservoir should be full of coolant. The cold mark on the larger side of reservoir is lower than the small column. So when it is cold, there is a tendency that coolant will flow from the small column to the larger side. The only reason that it does not flow to the larger side is because the cooling system is completely airtight so it can maintain this uneven level. This is a strange design to me. If the hose just connect to the bottom of the reservoir, will it be better? This way, we are not artificially create a tendency to draw something in.
As I circled in yellow line in the attached picture, this space is above the entrance of hose to reservoir and I always find a small air bubble here. I lean the reservoir and let the air bubble out, but it will appear again. I am confused where this air comes from. Maybe it is because I did not completely purge the air out when I flush the system so the small air bubbles walks its way out and end up being in this high place. It has been almost two month since I flush the cooling system and all the air bubbles should already walked its way out.
Any idea why I always see the small bubbles there? The coolant rise and fall as the car heat up and cool down normally.$(KGrHqZ,!hgFCF2BSE0vBQtSO-PfNg~~60_1.JPG
