Hello all,
I am rather new to the post. I have visited a few times over the years and found all of you to be very educated about the scenarios that come up which helped me fix my issues. I have had this car for 12yrs (has 150k) and have always kept everything in tip top shape, regular maintenance, old changed at 3k, etc.
Need some help because I am at lost. Dealership(s) have no idea
Issue:
car starts up fine when cold or sits overnight. When I drive it for a while and then immediately start again it fires right up. When I drive for 20 mins or longer and then let it sit and try to start I have to crank it for a long while to get it to start and it stutters for few seconds then idles back to normal. Exhaust is really rich fuel smell. At one point blacker then usual smoke came out . Once running it runs great. In the past year had tune up/spark plugs/wires replaced, fuel filter, MAF, fuel pressure regulator, TBI cleaned, idle air control valve replaced, fuel pump assembly. Tried seafoam to help clean as well and still at a loss of what it could be.
I travel a lot for work so took to the dealership while out of town back in Oct and they had off and on for 2 weeks. they did fuel pressure test a dozen times, spark test and gosh knows what else. Dealership was able to reproduce the problem and said believe to be the fuel pump so replaced fuel pump, but still same problem. I don't have a ton of tools to do my own test but can do some. Need help!!!!!!!!!!!!!!!!!
