Thread: Rear view mirror problems
Results 1 to 15 of 15
  1. #1 Rear view mirror problems
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    How do I get my rear view mirror on my 99 gtp to stop rattling from my subs? It's an auto dimming one with no compass any tricks would be appreciated thank you
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: Rear view mirror problems
    Sep 2011
    Copperas Cove, TEXAS
    Take off mirror, no mo problem.
  3. #3 Re: Rear view mirror problems
    The Boss Iceman6669's Avatar
    Jun 2011
    Or turn up the bass till it falls off....
    2011 F-150 Yote powered
  4. #4 Re: Rear view mirror problems
    Sep 2011
    Quote Originally Posted by Iceman6669 View Post
    HAHA, I have done this.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Mine still falls offf.
    Get like a gel super glue and glue that mofo on.
    If your bass is enough to rattle mirrors you shouldn't care about the people behind you
  6. #6 Re: Rear view mirror problems
    Oct 2011
    Michigan
    Mine isn't falling off it just vibrates and I can here it buzzing its annoying as ****, I would take it off but that probably is against the law
    Mar 2012
    Minneapolis MN
    The gel glue with soften it up a bit. I don't hear buzzing over my bass lol
  8. #8 Re: Rear view mirror problems
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Get a plain mirror with no options from the junkyard there won't be anything inside it to rattle. My dome light panal above the mirror rattles more than anything else I've determined.
  9. #9 Re: Rear view mirror problems
    May 2012
    Cedar Rapids, Iowa
    if you have dynamat cut a piece and put it behind the mirror.
  10. #10 Re: Rear view mirror problems
    Sep 2012
    Clarkston, MI
    Does the mirror just pop out? Foam would work also, right? I'll probably do that with my dome light panal.
  11. #11 Re: Rear view mirror problems
    GT Level Member wyrmscar's Avatar
    Jan 2012
    Orlando, Florida
    Quote Originally Posted by vandezand View Post
    i second this, sounds like a good plan in theory lol.
  12. #12 Re: Rear view mirror problems
    Oct 2011
    Michigan
    Just glue the dome light panel and yes the mirror just comes apart
  13. #13 Re: Rear view mirror problems
    SE Level Member Mellsthatguy's Avatar
    Dec 2012
    Michigan
    I glued the elbow of the mirror to the position i wanted it !
  14. #14 Re: Rear view mirror problems
    Yoga city
    have you tried to tighten it down? mine needs adjusment about once a month.
  15. #15 Re: Rear view mirror problems
    Oct 2011
    Michigan
    The mirror doesn't fall it just buzzes all the time
  1. ? About reAr view mirror in 97 gtp
    By jteske88 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2011, 02:20 PM
  2. Rear View mirror tab
    By Toasty in forum General Tech Discussion
    Last Post: 02-17-2008, 12:48 AM
