Hey guys. Does anyone know if the pushrods for ZZP Comp Cams 1.8:1 aluminum roller rocker set with lifters are supposed to be a little longer (3/8") than the stock pushrods? Also, I have confusing info with the set. The roller rockers are "Yella Terra" and the instructions say torque to 25 ft./lbs. between 1/2 to 3/4 turns after zero free play. The instruction sheet with the Comp Cams Pro Magnum hydraulic lifters says best setting is zzero to 1/8 turn. I thought I bought Comp Cams rockers but the Yella Terra's came in this package. I am running a stock cam in a 2002 GTP.
Thanks for any help!
TC
