Thread: here's a strange happening
Results 1 to 6 of 6
  1. #1 here's a strange happening
    Oct 2012
    illinois
    This has occurred twice when I was stopped at a stoplight. Foot on the brake and car starts surging almost like I was brake torquing it. At first I thought well maybe I was pressing on the gas pedal with the edge of my boot but the next time I made sure and switched to the left foot on the brake. very weird --any suggestions??
  2. #2 Re: here's a strange happening
    Pennsylvania
    Clean your TB and MAF, really cheap insurance. If it continues, unplug the MAF and drive around like that for a few days and see if the problem persists. I know a bad MAF can cause surging.
    Just some easy, cheap stuff to try/investigate before you start talking about more expensive avenues.
    Sport Edition Kv5 18x8
  3. #3 Re: here's a strange happening
    could be a vac leak.
    get some carb cleaner and spray around the engine at the vac lines and T's, while its running. if the idle jumps up, you found the area thats broken.
  4. #4 Re: here's a strange happening
    Pennsylvania
    Model year and miles always helps. He's driving a 1997 GT.
    Both of the above are good suggestions.
  5. #5 Re: here's a strange happening
    Oct 2012
    illinois
    Thanks I'll try those out. I know when I was changing my thermostat I accidentally broke a vac line connector on top so that's likely it.
  6. #6 Re: here's a strange happening
    Pennsylvania
    Oh, yeah, I imagine vac leaks are even worse on 97's, since they have that weird vacuum controlled transmission.
  1. Wierd things happening, I need help
    By thatguy in forum General Tech Discussion
    Last Post: 12-05-2011, 11:50 PM
  2. What would you do if this was happening
    By nyydmb12 in forum Off Topic Discussion
    Last Post: 07-02-2010, 02:16 AM
  3. What's happening!
    By rechristel in forum Introductions/Noob Questions
    Last Post: 06-28-2010, 02:20 PM
  4. 0.0000001 chance of this happening
    By bronzemist02 in forum Off Topic Discussion
    Last Post: 01-21-2010, 09:54 PM
  5. QUESTION about something wierd happening.
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 11:46 PM
