Thread: Need Help with my 01 grand prix gt 3.8l not super charged
Results 1 to 19 of 19
  1. #1 Need Help with my 01 grand prix gt 3.8l not super charged
    Mar 2012
    Michigan
    OK, I have fixed motor and tranny mounts, sway bar,bushings and links, lower control arms and bushings, top motor mounts and still hear this noise when I go to turn right, it sounds like it is coming from the front passenger side, but it only does it once when I turn my steering wheel to the right, and then it doesn't do it again. Can some please help me with this problem I am still having.
    Thank you Sammie
  2. #2 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Tie rods
  3. #3 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Never Never Land
    +1 for tie rods...do the inner as well. Most just do the outer but the inner wears out as well. You'll have to rent an inner tie rod tool from your local parts store.
  4. #4 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Mar 2012
    Michigan
    Those were changed too, this weekend, sorry forgot to mention that
  5. #5 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    inners outers or both?
  6. #6 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Could be strut mount
  7. #7 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    could be a bad strut mount. being that it looks like you have a whole new front end already.
  8. #8 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Mar 2012
    Michigan
    Ok, it was the outer tie rods, and the strut mounts and struts are new, had them replaced 4 wks ago
  9. #9 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    so the inner tie rods weren't replaced yet?
  10. #10 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Mar 2012
    Michigan
    No they were not
  11. #11 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    change them and see if it does anything. To bad it'll throw your alignment off and you'll have to redo it.
  12. #12 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    test the inner before you go and buy new ones. the same push pull test also works for the inner, being the outer tie rods are new, there should be zero play when you push/pull on the tire.
    inner rods do go bad, but they typically last much longer then the outer rods.
    this could even be the rack crapping out, hope not, but its a guess. check the rack bolts while your at it, one side gets a rubber bushing, maybe its worn out, or a bolt is missing? who knows right, just more stuff to look at.
  13. #13 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Mar 2012
    Michigan
    What do you mean by rack...I am just a grandma here trying to learn
  14. #14 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    steering rack. The thing that makes the wheels turn when you turn the steering wheel
  15. #15 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Mar 2012
    Michigan
    I hope not, it seems like I have been dumping money into this car and then it's one more thing that has to be replaced, It just never ends.
  16. #16 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    yeah the good old rack and pinion.
    being that you have almost a whole new front end, sort of the inner tie rods and the rack. id hope for a bad inner rod.
    oh, and check over the brake bolts, bracket and caliper. you never know.
    what does this sound like? popping/rattling? can you also feel it in the steering wheel?
  17. #17 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Mar 2012
    Michigan
    The sound is the same sound when my outer tie rods were going out but only on the front right passenger side is where I can hear it,sometimes I can feel it under the floor.But It only happens once and they I don't hear it again.
  18. #18 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    jack up that wheel, and do a push pull test at the 9 o clock position of the tire. it should be very tight feeling, any play could be the inner rod moving.
  19. #19 Re: Need Help with my 01 grand prix gt 3.8l not super charged
    Mar 2012
    Michigan
    Ok.Thank you
    Sammie
  1. 1997 Grand Prix GTP (Super Charged) Fuel Injector O-rings.
    By Ravenwald in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2012, 06:44 PM
  2. gt none super charged....
    By Jacob Turrentine in forum General Tech Discussion
    Last Post: 05-09-2012, 05:28 AM
  3. 3.8l super charged tach loss
    By fritzie001 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 12:41 PM
  4. super charged or not ?
    By 96gpse in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2010, 11:42 AM
  5. Super charged/non-super charged question
    By ohgreatone32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 10:31 PM
