Thread: Speed Daddy U-Bend Delete Modifications
Results 21 to 40 of 55
  1. #21
    I suppose it depends on how you cut it but yea Intrigue used the stock piping reread his thread if needed but adding additional pipe if needed isn't difficult if you have someone welding them for you.
    04 Comp G.
  2. #22 Re: Speed Daddy U-Bend Delete Modifications
    Oct 2011
    Toledo, OH
    Quote Originally Posted by bsharpminor View Post
    After having started hacking into my new SD headers... I disagree. I bought a pacesetter weld-in flex to replace the one that came with it. After staring at Intrigue's pictures and trying to assemble the pieces on my jig, it is short a few inches of pipe. Staring and arguing with my uncle about how to make it work, we came to the conclusion that Intrigue used a slip-on flex which has roughly 2 inches of pipe on both sides and provides pipe to slip into the race-pipe/cat. This may have been obvious to some, but not to me. I will now be sending back my weld-in flex and buy a slip-on.
    Just saying so that if somebody else reads this they can learn from my mistake.
    Good to know. I'm keeping my cat so I'll just use the included straight pipe for any extra I need, and the V-Band flanges will give me a few extra inches as well.
    7"
    Jan 2009
    Tallahassee, FL
    I'm not sure if its been asked before but I've already got a 3" DP, would that work with SDs?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #24 Re: Speed Daddy U-Bend Delete Modifications
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    Quote Originally Posted by Sandman View Post
    Been asked like a thousand times. Headers will replace the down pipe.
  5. #25 Re: Speed Daddy U-Bend Delete Modifications
    Mar 2012
    Minnesota
    It isn't difficult to add extra pipe except that nobody in the area has any 3" OD stainless pipe. Made a half dozen phone calls to machine shops/steel shops and nobody had any stainless. When you get into western Minnesota, there isn't much around, so I have to change my plan. I don't know that I'll have time to deal with them again until spring break; doesn't work to have your daily in pieces for more than a day, so if things don't work like planned, you're screwed.
    Try Frozenboost.com I believe they sell some SS piping and if you know the angle you'll need it'll be even better. I would make sure you go with SS especially living in MN. Nonesense my DD been sitting in my driveway for the past year I manage to get around lol but I do understand.
    04 Comp G.
    Jan 2009
    Tallahassee, FL
    I understand that. I wasn't sure if I could use the DP I use and not worry about the SD DP nonsense
    77 Morris Garage B
  8. #28 Re: Speed Daddy U-Bend Delete Modifications
    Mar 2012
    Minnesota
    To be honest I have no idea if you could do that. Here's pic of what I have hacked apart on the rears to this point on the headers, depending on your dp, maybe you could modify it/weld it to make it work.
  9. #29 Re: Speed Daddy U-Bend Delete Modifications
    Mar 2012
    Minnesota
    Crappy photo, but got it done. Thanks everyone for your help.
    Woot. The worry about bottoming out on the bend is now eliminated looks good.
    04 Comp G.
  11. #31 Re: Speed Daddy U-Bend Delete Modifications
    Intrigue would have used a ZZP dual wall flex. I know him and am sure that's what he had on hand.
  12. #32 Re: Speed Daddy U-Bend Delete Modifications
    May 2008
    Schuyler, NE
    I did the exact same thing. I tried it a few times with just the flex on the rear of the header, but kept ripping it. So, I added one in the downpipe just like that, and haven't had a problem with it yet.
  13. #33 Re: Speed Daddy U-Bend Delete Modifications
    Mar 2012
    Minnesota
    I used the ZZP dual wall flex as well, I know that's not what I had in my OP, but I wound up getting one and using it. I also wound up needing about 6 inches more of stainless pipe.
  14. #34 Re: Speed Daddy U-Bend Delete Modifications
    Jun 2013
    Hollywood ,FL
    do you really need to add an o2 bung i ordered a speed daddy header i know i need and 02 extension and a flex pipe and also them clamps what else do i need
  15. #35 Re: Speed Daddy U-Bend Delete Modifications
    ^ Not unless your either unhappy with the original location or if you want to add a wideband to it.
    04 Comp G.
  16. #36 Re: Speed Daddy U-Bend Delete Modifications
    Jun 2013
    Hollywood ,FL
    What's a wide band ?
  17. #37 Re: Speed Daddy U-Bend Delete Modifications
    No offense dude but if you dk wht it is then you don't need to worry about having one right now. Google it if your curious.
    04 Comp G.
  18. #38 Re: Speed Daddy U-Bend Delete Modifications
    May 2013
    Tacoma, WA
    Can i go a cheaper route and buy an extension and use the factory O2?
  19. #39 Re: Speed Daddy U-Bend Delete Modifications
    Sure can hell I made my own. Splice and extend a few wires and blam easy as pie.
    04 Comp G.
  20. #40 Re: Speed Daddy U-Bend Delete Modifications
    No, because whats going to read that o2?
    A wideband comes with a gauge that is made to convert a specific o2 sensor's readings into real time Air-Fuel Ratio numbers.
  1. u bend delete
    By kking89 in forum General Tech Discussion
    Last Post: 05-18-2011, 06:05 PM
  2. U-Bend Delete
    Last Post: 04-18-2011, 06:02 PM
  3. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  4. U-Bend Delete?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 12:45 AM
