Thread: High beams "point down"
Results 1 to 14 of 14
  1. #1 High beams "point down"
    Aug 2008
    Ohio
    I have had some ongoing issues with a recently purchased used 98 GP. I have replaced the headlight housings and bulbs and it helped some. Biggest issue now is with high beams--when activated the seem to "point down" and not down the road at all.
    Any help is appreciated.
  2. #2 Re: High beams "point down"
    GT Level Member BackInBlack's Avatar
    Vermont
    Any electrical modifications to the car? Check to see that the bulbs are seated firmly and that they are not 9004 bulbs. Park 20 feet from a vertical wall at night and take some photos of your low and high beam patterns.
    The GPs are long gone...
  3. #3 Re: High beams "point down"
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    Other than what backinblack said, I'm not sure if the older body GP's have the reflector on the high beams or not but on my headlights that's what made mine seem to tilt incorrectly. Also if you have replaced your housings and they're not OEM they might not fit perfectly, you can always try moving them a little.
    *sig is too tall*
  4. #4 Re: High beams "point down"
    Aug 2008
    Ohio
    Here are pictures taken last night 20 feet from wall.
    1st--Low Beams
    2nd--High Beams
    High beams "point down" Attached Images
  5. #5 Re: High beams "point down"
    Vermont
    Check to be sure the bulbs are seated all the way. The metal stop ring can sometimes get loose off the back of the plastic housing. What brand 9007 bulbs do you have in there? I bought some crappy ones a while back that were made incorrectly, and the filaments were not in the right positions. Stick with brand name like Philips, Osram, Sylvania and GE.
  6. #6 Re: High beams "point down"
    Aug 2008
    Ohio
    I tried "going cheap" and bought these off 3bay, but the original sylvania 9007 were even worse. I was going to go silverstar, but wanted to try a less expensive route first.
  7. #7 Re: High beams "point down"
    Vermont
    Do you have the original stock headlamp capsules? Check those metal rings...
  8. #8 Re: High beams "point down"
    SE Level Member MichEE's Avatar
    Aug 2008
    Michigan
    Quote Originally Posted by BackInBlack View Post
    Good idea... also I had a problem where the whole lens was not set into the grill properly. That effected hi and low beams though.
  9. #9 Re: High beams "point down"
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Metal light diffuser will not cause that.
    Your bulbs are upside down. Turn em right side up and then see what happens
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  10. #10 Re: High beams "point down"
    Vermont
    The base of the bulb is keyed, so you shouldn't be able to install them improperly. I did have a set of 9007 bulbs once that were manufactured incorrectly, and the filaments were way out of whack. Produced horrendous output...
  11. #11 Re: High beams "point down"
    Tulsa, Ok
    not all bulbs are keyed.
    I have my old set of stockers and they are not keyed. Phillips bulbs
    98' GS - Sold
  12. #12 Re: High beams "point down"
    Vermont
    9007 bulbs are though.
  13. #13 Re: High beams "point down"
    Tulsa, Ok
    im looking at my old 9007 bulbs these do not a key.
    98' GS - Sold
  14. #14 Re: High beams "point down"
    Vermont
    Quote Originally Posted by Toofastgs View Post
    Key. There are two of them, offset by not quite 180°.
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Inferno Appearance" or 06 "SE Appearance Package"
    By romande in forum Visual/Body Modifications
    Last Post: 04-02-2011, 12:56 PM
  3. Interior Paint ~ Headlights and High beams
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 09-19-2008, 02:34 PM
