Thread: 2000 GT after market air intake kit, now cel?
Results 1 to 16 of 16
  1. #1 2000 GT after market air intake kit, now cel?
    Dec 2012
    Des Moines, IA
    Hey guys. Im new to this forum site, but not to my car. I've had my 2000 GT since 2007 and this is my first time upgrading to an aftermaket air intake kit with cone filter...car currently has 135,700 miles on the clock.
    Installation went as smooth as can be with no issues. I made sure everything was installed the way its supposed to be without taking short-cuts. I made sure everything was complete and plugged in before turning the car back on. The car performed perfect with better mpg for the first day, then...check engine soon/cel light came on. "temp air sensor" comes up for the code on ODBII. How can I fix this issue even though this isnt hurting my engine??? Is there an aftermartket sensor? Do I need to tune the cpu? Any other suggestions, please?
    Thanks
  2. #2 Re: 2000 GT after market air intake kit, now cel?
    Look up the code and figure out why the car threw it.
    It should have some sort of diag chart you can go down.
  3. #3 Re: 2000 GT after market air intake kit, now cel?
    SWPA
    You might have damaged the IAT when removing or replacing. Make sure its firmly plugged in.
  4. #4 Re: 2000 GT after market air intake kit, now cel?
    Dec 2012
    Des Moines, IA
    The code said the temp air intake sensor has high input. Another guy just said make sure the sensor is facing the correct way.
  5. #5 Re: 2000 GT after market air intake kit, now cel?
    Dec 2012
    Des Moines, IA
    Has anyone else had this issue before?
  6. #6 Re: 2000 GT after market air intake kit, now cel?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Maybe take a picture?
    So we can see the installation.
  7. #7 Re: 2000 GT after market air intake kit, now cel?
    Dec 2012
    Des Moines, IA
    Here is a photo of my setup.
    ...A gear-head in my own way...
  8. #8 Re: 2000 GT after market air intake kit, now cel?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    The stock airbox is set up to draw cool air that gets forced in through the fenderwell. In your set up you have the filter hanging right over the hot exhaust crossover pipe. The intake air temp sensor is probably reporting that the intake air temp is too high....probably because it is. You're actually losing efficiency here because even if the filter is less restrictive, you're pulling in much hotter air. You need to move that thing out to the fenderwell so it can draw cool outside air, not hot underhood air.
  9. #9 Re: 2000 GT after market air intake kit, now cel?
    SWPA
    There is nothing wrong with his set up.
  10. #10 Re: 2000 GT after market air intake kit, now cel?
    Apr 2012
    Goderich, Ontario
    I don't see anything wrong with your setup either. Having the filter in the wheel well is ideal, however, a lot of ppl on here just put the filter directly on the throttle body. Maby the AIT censor is damaged? Try unplugging your battery for 1/2 hr. to reset your PCM.
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by Burbman View Post
    Actually if I understand it right, warm air is better for fuel economy.. Cold air makes more HP. Also, I run a set-up VERY similar and dont get the SES code...
    2011 F-150 Yote powered
  12. #12 Re: 2000 GT after market air intake kit, now cel?
    Jun 2011
    My setup looks almost identical.
    I get no codes from it.
    His setup is just fine. Its got to be your IAT sensor.
  13. #13 Re: 2000 GT after market air intake kit, now cel?
    Dec 2008
    ****'s Creek
    I stand corrected...sorry guys.
  14. #14 Re: 2000 GT after market air intake kit, now cel?
    make sure its plugged in, if it is, go buy a new iat sensor, they cost like 10 bucks.
  15. #15 Re: 2000 GT after market air intake kit, now cel?
    Dec 2012
    Des Moines, IA
    I'm going to get a new sensor and try this first. I would like to note: my last visit to the shop having some work done on my radiator, the sensor did throw the same code after i got home a couple months ago...with my stock box setup. I ignored it and cleared the code then the sensor never came back on til I installed this new kit. I hope it's the sensor damaged. I will try this and let you all know what I find out. Thanks!
  16. #16 Re: 2000 GT after market air intake kit, now cel?
    Dec 2012
    Des Moines, IA
    Alright, guys. I replaced the sensor, then cleared the code. I've driven over 50 miles so far since yesterday and no cel! I believe we have it accomplished. I'm also getting 30mpg at 70 mph! Loving it!
  1. 2000 Grand prix GT air intake question
    By ZachBW55 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2012, 10:30 AM
  2. Will a WizAired Cold Air Intake box from an 04 fit on my 2000 GT?
    By GPrixGT00 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2011, 07:14 AM
