Thread: Supercharger bolt
Results 1 to 6 of 6
  1. #1 Supercharger bolt
    Oct 2012
    Vacaville, Ca
    I have a 99 grand prix GTP.. i need to change the supercharger oil but the bolt that gets me to check and fill the oil is stripped to hell from the previous owner and a little by my attempts to fix it. Does anyone know where i can get a replacement bolt because i havent been using my supercharger and its been rough. Any help would be appreciated. The picture below is what it looks like now.
    Supercharger bolt Attached Images
  2. #2 Re: Supercharger bolt
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: Supercharger bolt
    Oct 2012
    Vacaville, Ca
    Quote Originally Posted by asite57 View Post
    Thank you, I would have never found it
  4. #4 Re: Supercharger bolt
    Nov 2012
    Lebanon missouri
    I have seen them on ZZP too.
  5. #5 Re: Supercharger bolt
    I live here. TLSheff's Avatar
    You could also order one from your local GM Dealer.
    GM# 24500661 - Plug - Retail $8.30 +tax
  6. #6 Re: Supercharger bolt
    im sure that can be found at a good hardware store, or take it out, the one you have and cut a slot in it, then you can use a flat head screwdriver to take it off and on. thats what i did when mine stripped out, and just so you know some are Allen keys, and other use a torx bit.
    yours looks like it used to be a torx.
  1. I need a supercharger idler pulley bolt
    By FaxMeBeer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2011, 12:55 PM
  2. Supercharger bolt length gen 3
    By sseilmnop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2011, 09:55 PM
  3. Supercharger vented bolt???
    By jagamite in forum General Tech Discussion
    Last Post: 11-04-2008, 08:13 AM
  4. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
