he everyone how are you? Just a quick question for you guys , I was just wondering is it safe to flash my PCM back to stock and then re-do a tune and install it ? thanks for your help !
You never need to do "write entire".
And yes you can flash it back to stock then change stuff and flash it agian before you ever start or drive the car.
Flashing it back to stock is not needed if you just want to flash it to whatever file you want.
ok cool , i was trying to set up my maf hz and when scanning i was looking at the gauges to watch my KR and the indicator For the LT B1 was all red , have no clue why that happened
It might be the 60lb injectors you mention in your other thread that you didn't account for.....just an idea. wink wink.
Pull up a stock bin file in editor, add in the injectors then save that file as #1 or anything that denotes it's your beginning point. Flash that to the pcm. Then start your tuning for the ported TB, ported SC and ported LIM. That'll all be basically covered when you tune the maf.
I'd follow the instructions I gave you in the other thread.
Find Matt5112's post about injectors and voltage offsets etc. It was a link to all the cool kid data. Then you merely type that into the voltage offset area and change the injector flow in that table.
