Sent the injectors on the 01 GT out to be cleaned, here is the report showing the before/after flow bench results. Before on the left after on the right.
Only 1 of the 6 injectors was performing at spec, the other 5 were variously degrees of plugged. The "after" test shows them all performing identically at spec. Ironically the injectors on the 98 showed better "before" results than these did with about the same mileage (153K).
