Thread: Window cable?? 98 Grand Prix GT 4 door
Results 1 to 12 of 12
  1. #1 Window cable?? 98 Grand Prix GT 4 door
    SE Level Member markh's Avatar
    Aug 2008
    North Haven CT
    Dealing with the infamous upper manifold leak and the car has been sitting for a week with the battery disconnected. Notice this morning that the drivers rear window is about half way down and I KNOW all the windows were up.
    Pulled the inner panel off the door and see that there is a stainless steel cable in there that is loose. I can actually move the window up and down by hand. Cable does not appear to be broken and looks like it is still connected on each end. What to do???
  2. #2 Re: Window cable?? 98 Grand Prix GT 4 door
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    i believe that there is a little plastic clip on the inside of the regulator that can break and leads to this problem, if that is the case then your best bet would be to tear apart the regulator and replace that clip
  3. #3 Re: Window cable?? 98 Grand Prix GT 4 door
    Jul 2008
    sumter,south carolina
    replace the whole regulator they arent expensive
    02 GTP with mods 05 GP for DD
  4. #4 Re: Window cable?? 98 Grand Prix GT 4 door
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    I have been messing with mine for the last two days now. The cable was cross threaded inside the motorized mechanism, the cable was disconnected from the plastic clip stlomo_gtp was describing above and the rubber track inside the door was off.
    Trying to fix it is a nightmare and purchasing the whole new mechanism is faster and easier.
    However i like to see how everything works and adore the feeling of fixing it myself so ill continue to try until i head back to school tomorrow. [I think i may have got it ]
    2006 Grand Prix GXP
  5. #5 Re: Window cable?? 98 Grand Prix GT 4 door
    Feb 2008
    I had this same problem on my car, except it was my RR. Unfortunately the plastic that holds the end of the cable is part of the slide that actually holds the glass and it is designed poorly and breaks, there are no clips to replace. You are looking for a replacement window regulator. I got my replacement from Auto Zone so I could get the lifetime warranty. But they are way cheaper on eBay.
    Easy to do, I'm sure you can handle it. A helpful hint, manually lift the window all the way up and get some packaging tape and put 2 or 3 strips on the outside of the window to hold it up while your changing your regulator.
  6. #6 Re: Window cable?? 98 Grand Prix GT 4 door
    Jul 2008
    New York
    Quote Originally Posted by Blown97 View Post
    Also make sure to do this after you unbolt the two 10mm bolts from the window as they are un-assessable when the window is rolled all the way up.
    2006 Grand Prix GXP
  7. #7 Re: Window cable?? 98 Grand Prix GT 4 door
    GT Level Member njbrain's Avatar
    Rhinelander WI
    It isn't worth messing with. If it derailed in the first place, it is worn out enough to head south again. They are only like $150 new from CarQuest and AutoValue.
  8. #8 Re: Window cable?? 98 Grand Prix GT 4 door
    Feb 2008
    Quote Originally Posted by DnaProdigy View Post
    Ahh yes, I remember....Good point DnaProdigy!!!
  9. #9 Re: Window cable?? 98 Grand Prix GT 4 door
    Jul 2008
    New York
    Thanks.
    Quote Originally Posted by njbrain View Post
    Yea i have been pricing them out and i think you can get one on ebay for only like $60. I was looking at one for my RR door in my 99 GTP so not sure if prices are different for newer years or different doors.
    2006 Grand Prix GXP
  10. #10 Re: Window cable?? 98 Grand Prix GT 4 door
    Aug 2008
    North Haven CT
    Thanks guys, I ended up getting one on ebay for $50 shipped new. Supposedly has a 1 year warranty.
  11. #11 Re: Window cable?? 98 Grand Prix GT 4 door
    Jul 2008
    New York
    Quote Originally Posted by markh View Post
    Yea i'm doing th same with mine. Cost is about $62 shipped. I messaged the seller and he said that they pay for return shipping if they send the wrong part. And the warranty covers any defects in the product as well as anything that may malfunction a year after sale.
    Do you have the link the the person/company selling them for $50 shipped?
    2006 Grand Prix GXP
  12. #12 Re: Window cable?? 98 Grand Prix GT 4 door
  1. Cable on window regulator comes off [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-24-2015, 04:44 PM
  2. New Guy with '04 Grand Prix GTP
    By NSUstud in forum Introductions/Noob Questions
    Last Post: 10-01-2008, 07:44 AM
  3. Grand prix door panels
    By 97gp97 in forum General Tech Discussion
    Last Post: 08-08-2008, 08:46 AM
  4. Re-installing Door Window!!!
    By m0ng00se in forum General Tech Discussion
    Last Post: 08-08-2008, 08:45 AM
