Thread: Same mystery leak
Results 1 to 7 of 7
  1. #1 Same mystery leak
    Oct 2012
    Prescott valley
    Hey every one this is my first post I Have an 04 gtp with 193000 miles and it has the mystery front oil leak on the passenger side of the car. I have removed and replace the oil filter adapter gasket as well as removing the oil pressure sender and cleaning and resealing the threads the leak stopped for a day or two and now I have a new leak still on the front cover side. I know its not the sender watched it with my girlfriend holding it at 3000 rpm no drips. Any ideas im thinking timing cover or front crank seal. Also I have oily residue on my supercharge idler and all over the timing cover but moraeso on the rights side of it
  2. #2 Re: Same mystery leak
    Clean it.. have the girl do the same...this time naked (you know that would be better for you) and then fix the leak.
  3. #3 Re: Same mystery leak
    Oct 2012
    Prescott valley
    Lol will do im doing the timing covers gaskets this weekend since it needs a w/p anyways picked up the timing cover, waterpump and front crank seal gaskets for 20 dollars gotta love rock auto
  4. #4 Re: Same mystery leak
    GT Level Member Peacher213's Avatar
    STL Metro Area
    Quote Originally Posted by 04gtpballin View Post
    I love Rock Auto. I live 20 minutes away from their warehouse so I get my stuff overnight.
    99 GTP coupe
    Stock, other than open cone filter.
  5. #5 Re: Same mystery leak
    Oct 2012
    Prescott valley
    Way better than vatozone lol
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Still can't beat napa
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  7. #7 Re: Same mystery leak
    Oct 2012
    Prescott valley
    forgot to update on this it was both the front crank seal and the timing cove leaking... gasket set fixed it no problem
  1. mystery leak on driveway only when parked on incline (even slight)
    By robshaver in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2012, 01:15 PM
  2. Mystery oil leak
    By thatguy in forum General Tech Discussion
    Last Post: 04-17-2012, 07:58 AM
  3. Mystery coolant leak
    By 04silverprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2011, 11:35 PM
  4. mystery problem
    By jspangler22 in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2011, 03:41 PM
  5. Oil line mystery
    By 62duoglide in forum General Tech Discussion
    Last Post: 04-12-2011, 05:14 PM
