Thread: Good battery reccomendation?
Results 1 to 16 of 16
  1. #1 Good battery reccomendation?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Recently my car has been really slow to turn over as it has been getting colder outside, went to start it this morning in 32F weather and no dice. Anyway, I'm looking for a good battery I have looked into the Optima Red Tops even with the high price tag my dad was explaining its a good idea to get a reliable good battery. I found this one at autozone ->Optima Battery/Battery (34-78) | 2002 Pontiac Grand Prix 6 Cylinders K 3.8L SFI OHV | AutoZone.com. I guess any opinions, experiences, or recommendations would be grateful.
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: Good battery reccomendation?
    Interstate.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    I have a red top and it has never let me down no matter what I throw at it.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  4. #4 Re: Good battery reccomendation?
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Get one with 690+ cold cranking amps. Look for a little round sticker on the side, it will show the build date. Some have a letter first: A for January, B for Feburary -others have a number 1 for January. The next number after the slash is the year. Look close as some retailers may have had batteries on the shelf all summer that are being sold now as it gets cold. Trickle charge it overnight at least before you put it in.
    Brand is not as important as warranty and CCA. Buy it where you think a possible return would be the easiest.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  5. #5 Re: Good battery reccomendation?
    Apr 2012
    Dayton, OH
    Quote Originally Posted by Madness View Post
    Would trickle charge mean throwing it on a battery charger with low amps? I have some cheap battery charger that I got from autozone thats got like 10,6,2 amp settings or something along with standard,AGM,and some other battery type.
    2012 F150 STX
    Batteries have recharge dates on them for this reason.
  7. #7 Re: Good battery reccomendation?
    Max Cook
    Guest
    Quote Originally Posted by Sushamouf View Post
    Sent from my Droid
    This! I dont know if i've just gotten lucky with getting a good one or what. I mean I know they're expensive but I bought this car in 2008 and it already had it in there for 2 years. So its around 6 years old. I store it every winter by simply unplugging it (no trickle charge). For the first year I accidently left it plugged in while it sat for about 5 months (car started right up). Its probably sat unplugged for 3 years of overall time. I've had it drain dead on me for stupid reasons at least 4-5 times. It always starts right up and is still giving me about 14.8V. Thing is bad ass.
  8. #8 Re: Good battery reccomendation?
    Grand Rapids, MI
    I got one of the Advance gold ones or whatever. Used online codes and got $20 off or so. It's got almost 800 cca. Does just fine.
  9. #9 Re: Good battery reccomendation?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Also don't foget you can throw in a 75 series battery, most of the time the cca's are the same but the battery is 8-10 lbs lighter in smaller packaging. It works great for cranking it over, probably not as much so if you are running a big sound system though.
  10. #10 Re: Good battery reccomendation?
    Apr 2012
    Dayton, OH
    Quote Originally Posted by addzradd View Post
    All I got is 2 12's on 500w rms and my headlights dim when I crank it. I plan on doing the big 3 soon with 4ga wire.
    2012 F150 STX
  11. #11 Re: Good battery reccomendation?
    Run more wire to the amp then.
    More CCA/ lb results in lower life expectancy.
    Similar to halogen light bulbs.
  12. #12 Re: Good battery reccomendation?
    Apr 2012
    Dayton, OH
    Everyone has been a big help, I'm looking into an Optima Red top if the money is available or a Duralast Gold because of location for warranty reasons.
    2012 F150 STX
  13. #13 Re: Good battery reccomendation?
    Nov 2009
    A little late
    don't forget about the customer service at whichever vendor you choose
  14. #14 Re: Good battery reccomendation?
    Apr 2012
    Dayton, OH
    Well guys, I got a Duralast Gold Top something 800CCA (can't remember rest of it) Has a 3 year replacement warranty and an 8 year warranty for credit if it goes bad after the 3 year. When they tested the 6 year old wal mart everstart battery it was bad and was bulging and he said frozen and only put out like 400CCA and was rated at 580CCA. Installed the new battery in my car and holy crap, It fired right up the starter sounded nice a healthy. Took her for a drive to let the computer re-learn and everything is good.
    2012 F150 STX
  15. #15 Re: Good battery reccomendation?
    Grand Rapids, MI
    Yep. That's the same one I got. I made it all through last winter and this summer and it's been a champ. Hell it better be or I will surely take it for a return
  16. #16 Re: Good battery reccomendation?
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    For me, I've always just bought the highest CCA battery in my group size from the local farm supply store. I just replaced mine since it was 9 years old and dieing, with a Road Runner 850 CCA for $85. My top negative top post cable would not reach, so I had to buy a $2 screw in side post adapter. Works good for me. My last car I was able to fit in an 1100 CCA battery, but I did that because it was really struggling in the cold.
  1. HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2012, 09:10 PM
  2. Battery
    By Lishap in forum General Grand Prix Discussion
    Last Post: 03-17-2012, 12:11 AM
  3. Amp to Battery
    By SE2001 in forum Audio, Security & Visual Electronics
    Last Post: 02-11-2012, 02:33 PM
  4. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
  5. HID kits Reccomendation
    By french080 in forum Visual/Body Modifications
    Last Post: 01-25-2009, 03:46 AM
