Thread: ignition control module EMERGANCEY
Results 1 to 7 of 7
  1. #1 ignition control module EMERGANCEY
    Sep 2012
    Green Bush ON
    Jumped in my car today to drive my kids to school car started up fine loaded my sun in his car seat and hoped in the drive side back out the car to the road and put it in Drive car almost stalled out then chirped the tires and lvl'd out thought this was relly off i made it about another 100m er so and the car just went dead ? i checked the fuel pump and sending unit there all working fine so i had to have the car towed to my dealership there saying its the ICM and they ordered a used one for $110 CAN. the cars a 2008 Grand Prix Base. and ive only had the car 60 days as of today there makeing me pay for the part and the dam tow apprently its not covered under my bumper to bumper 100,000 warranty or my Drive train warranty so should they cover it under the 60 day lemon law
    and how long would it take to install this ICM unit ?
    so if i have to pay for it im not getting soaked for Labor
    hit me back please lads
  2. #2 Re: ignition control module EMERGANCEY
    you could buy a used one from a junk yard and change it yourself in less then 20 minutes.
  3. #3 Re: ignition control module EMERGANCEY
    Sep 2012
    Green Bush ON
    Thanks Scotty but im no good wit a wrench just have a decent knowledge of whats under the hood.. so it should not cost me much to have it replaced then if its only 20 min
  4. #4 Re: ignition control module EMERGANCEY
    im sure they will nail you for a full hour.
    its under the coils, take the coils off then the icm, and the unbolt the plug at the front. its easy.
  5. #5 Re: ignition control module EMERGANCEY
    May 2016
    Lincoln, Nebr
    I have an 08 GP base model. I'm on my third ICM in 4.5 years. The first 2 were Duralast from AZ (lasted 39 months & 18 months). And now I'm running a BWD from AdvA. My plugs and wires are a year old, replaced with ACdelco iridium plugs and ACdelco wires. 6/3 coil was stock, 2/5 coil is Duralast, 4/1 coil was stock. The 2nd Duralast ICM stopped firing the 4/1 coil, so as a precaution I replaced the 4/1 coil with a BWD coil, since this is where the 1st Duralast ICM failed too.
    Does anyone have a clue to why these ICM's would be crapping out on a somewhat regular basis? Is it just poor quality chinese parts or should I be looking for something else?
  6. #6 Re: ignition control module EMERGANCEY
    hit up a junk yard and buy a used oem one. sometimes old used stock parts are better.
  7. #7 Re: ignition control module EMERGANCEY
    hangover park IL
    A lot of the aftermarket ones are junk
    ~James~ Psychotic Gearhead
  1. HELP! Ignition Switch: Removing Passkey Module
    By Lawngoose in forum General Tech Discussion
    Last Post: 06-20-2009, 05:44 PM
  2. Possible Ignition control module problems?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 05:04 PM
