Thread: testing fuel pressure on 04 grand prix and hard starting when hot
Results 1 to 5 of 5
  1. #1 testing fuel pressure on 04 grand prix and hard starting when hot
    Sep 2012
    ontario
    I have been having problems starting my car after its hot and sits for 20 Min's approx, I have to press the gas peddle to get it to start and turn it over lots
    what i have done so far is:
    1. changed fuel filter
    2. checked spark while the symptom is happening and with spark plug wire tester and it showed spark
    3. cleaned throttle body tore it apart
    4. cleaned MAF sensor it reads (g/s) 4.92 on obd2 (not sure if that is goo still learning about this)
    5. checked codes with obd2 scanner
    6. codes showed up as
    7. p0455 - p0128 i have a ect just have to change it my reading is 89 de C
    8. changed antifreeze (to prep for winter)
    What I get when I hook up my fuel pressure gauge and the car is running is 57-58 psi but when I turn my key off it drops to 0 right away is this normal?
    When I turn on the key without starting the car I can hear the pump priming but the gauge reads 0 psi till I turn it over quite a bit then the pressure climbs up to 57 psi and starts right away (again is this normal or is it not priming right? )
  2. #2 Re: testing fuel pressure on 04 grand prix and hard starting when hot
    GTP Level Member joe0813's Avatar
    Boston, MA
    i would say you need a new pump/sending unit.... when it primes you should be getting fuel pressure
  3. #3 Re: testing fuel pressure on 04 grand prix and hard starting when hot
    Sep 2012
    ontario
    That's what I was thinking new pump sending unit but its weird that it only does it when the car is hot . is there a reason for this ?
    i'm still trying to figure out the fuel system on this its the first time i ever seen one with out a return line at the motor and just a return at the filter does anybody have a good explanation for this because my service manual is not helping me at all !!!
  4. #4 Re: testing fuel pressure on 04 grand prix and hard starting when hot
    Its a returnless fuel system.
    Seems that tons of people are having issues with these cars hard starting after they are hot.
  5. #5 Re: testing fuel pressure on 04 grand prix and hard starting when hot
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by skinner View Post
    i would check the fuel pressure regulator for leakage.
    gpbastard
  1. hard starting
    By BlackGT97 in forum General Tech Discussion
    Last Post: 12-17-2011, 08:14 PM
  2. hard starting
    By Moriarity81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2011, 11:56 PM
  3. 2007 Grand Prix Starting Hard
    By packerfanjc in forum General Tech Discussion
    Last Post: 06-13-2011, 10:22 PM
  4. testing fuel pressure?
    By bonesz28 in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-15-2009, 11:12 AM
  5. Help Car Hard Starting
    By rstark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2008, 06:24 PM
