Thread: Wipers on crack?
Results 1 to 10 of 10
  1. #1 Wipers on crack?
    Aug 2012
    RI
    Ok so my car's wipers work all the time on high, and randomly on all the other settings. Most commonly in the early morning it will work on all settings for like 3 mins then doesn't and if i hit a bump does again for like 30 seconds? I'm thinking wiring?
  2. #2 Re: Wipers on crack?
    Could be a bad switch.
  3. #3 Re: Wipers on crack?
    bad multi switch would be my guess. thats the arm with the controls on it, blinkers, cruise.
  4. #4 Re: Wipers on crack?
    Aug 2012
    RI
    can anyone tell me how to get it out so i can test it with a volt meter before spending $300(price based of autozone)?
  5. #5 Re: Wipers on crack?
    SWPA
    Why would you spend $300 at AutoZone when you can get a switch at a junkard for $5?
  6. #6 Re: Wipers on crack?
    Aug 2012
    RI
    Whhhhaaaaaaaa?!?!?!?!?!?
  7. #7 Re: Wipers on crack?
    its under the plastic around the steering wheel, you need to take that off, with out breaking it, and then the plastic and metal shield under that, then un hook it from under the dash.
    i took my wheel off last time i was in there to change the multi switch. made it easier to work on.
  8. #8 Re: Wipers on crack?
    GT Level Member sasquatch094's Avatar
    cleveland
    Not sure what year your talking about, but my 05 grand prix has the "whos got the crack syndrome"
    Theyll work fine at anyspeed, then all off a sudden they crack out, get stuck, and will only work on the high speed setting. Give it a few minutes and itll be back to normal. Its not the arm for the turnsignal and such.
    Ive read that the wiring harness connections under the cowl can get soaked in water and also the linkage cant get dirt and debris on it creating this problem. both with are free to fix if you have 5 min.. id check into it before anything else. Take the connector apart and see how the pins are, coat with some dielectric grease and try to seal it up better or hide it from rain water...
  9. #9 Re: Wipers on crack?
    Aug 2012
    RI
    i got a 99 buick regal but ill get in there over the weekend, and see what i can figure out
  10. #10 Re: Wipers on crack?
    Dec 2012
    ohio
    Hey I'm thd one in mogadore that had the 01 pace car the silver grand prix what did you want to know about it? I
  1. Crack in Transmission
    By BatmanBob in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2014, 09:52 AM
  2. This is a crack, right?
    By hshift in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2013, 08:31 AM
  3. Lil Crack's day with dad
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 03-14-2012, 01:29 PM
  4. Crack pop clunk
    By Green97GTP in forum Brakes/Suspension/Chassis
    Last Post: 11-06-2009, 06:47 AM
  5. Crack heads!
    By SlowM90 in forum The Rant Forum
    Last Post: 09-07-2009, 11:43 PM
