2001... 3.8 97,000 miles non supercharged
I have posted a few times, about my car stumbling at around 12 mph and then again at 18 mph..when i get to 18 mph and immediately release the gas pedal the engine or trans will stumble hard. Only when the car has warmed up.
I decided to jack the car up and get the front wheels off the ground to check voltage and to visually see this happen in action.... when it gets to 18 mph it will stumble and shoot axle grease near the radiator bottle simultaneously..the driver side also but a small amount. I noticed it was some grease already Underwood, so this has probably been occurring , just when the wheels were off the ground no pressure on them, it allowed the grease to shoot out freely.
Now if it was the axles that were bad it would happen all the time I'm guessing..so Its the trans or some sensor making the trans shift erratically. Is shooting grease out normal when having the tires off the ground.
I changed fluid and filter a few weeks ago and it didn't change the condition.
My question is , is their a way to re grease the axles ( have them service) because they both lost some grease. What should I do now. their are no codes I guess a trans shop will be my next stop.![]()
