10,000 mile update!
New Suspension:
Excel-G 339015 Front Struts (06+ Style, FE4 Spec)
Excel-G 339148 Rear Struts (06+ Style, FE4 Spec)
Stock CompG Springs
Monroe Strut Mounts
Stock CompG Rear Swaybar
Dorman Front Swaybar
06+ Style LCA's
Timkin Wheel Hubs at all 4 corners
New headunit: Pioneer AVH-X3500BHS
New Steering:
New Rack / Pinion
New Inner and outer tie rods
New Power Steering Pump
New Power Steering Return Line (Rusted out and leaked, causing the above to fail)
New Brakes:
Brakemotive Drilled / Slotted front and rear brakes
New Tires:
Dunlop Signatures
Other:
Replaced the Washer Fluid Level Sensor and connector (Corroded pins)
To Do:
Find / Install an 04 GTP ABS Module, the GT one installed is not compatible with the GTP PCM cal.
Install the HUD from the CompG into the GT
Install the 5 Channel Kicker Amp / Kicker QS 6.5's I have sitting here
Track down the source of my EVAP DTC (Replaced the gas cap, no change)
So far this car has cost a lot more then I planned, but as it stands, it's pretty much brand new!
-Rob
