Thread: Popping when put in and out gear.
Results 1 to 14 of 14
  1. #1 Popping when put in and out gear.
    Aug 2012
    Sacramento
    I recently replaced all the brakes on my 2001 gtp and while there replaced the half shafts because they had a fair amount of free play in them, I know one of the ball joints is bad and that would explain the popping while turning but would it explain why theirs a pop as the cars being put in and out of gear? Possibly a transmission mount? If so are is there a write up on swapping the mounts?
  2. #2 Re: Popping when put in and out gear.
    Motor mounts are my first guess.
    Popping while turning is likey an axle, but I guess you just replaced them.
    Ball joint seldom go bad on these cars.
  3. #3 Re: Popping when put in and out gear.
    Aug 2012
    Sacramento
    The right front ball joint is missing most of the boot so I planned on replacing it I did notice I have something on the underside of the motor thats leaking but the engine and tranny aren't losing any lubricants.
  4. #4 Re: Popping when put in and out gear.
    Could be the oil pan, valve covers, power steering lines, you'd have to get under it and check.
  5. #5 Re: Popping when put in and out gear.
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i would think poping when taking in and out of gear would be either trans or motor mount one under the oil pan
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    My motor jumps about 3 inches between park and every other gear... working on getting it fixed soon
    Btw. Are motor mounts DIY capable?
    There is 2 lower ones right?
  7. #7 Re: Popping when put in and out gear.
    Aug 2012
    Sacramento
    I've been under it, the leak may have been prior to me owning it it hasn't gotta any worse simply put the pan is coated in a thin coat of fluid, but I'll double check everything. What is the procedure for swapping the mounts out loosen the top mounts and jack the motor up?
  8. #8 Re: Popping when put in and out gear.
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    you mean lift the motor up seen to many crushed oil pans on customer cars
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  9. #9 Re: Popping when put in and out gear.
    Use a big flat board and jack, spread the weight out and you wont crush anything.
    Ohio
    Only do one side at a time though. So leave the trans mount attached, undo the engine mount, replace it. Then do the trans mount
  11. #11 Re: Popping when put in and out gear.
    antioch ill
    everytime i see this thread i think it says pooping not popping
  12. #12 Re: Popping when put in and out gear.
    Aug 2012
    Sacramento
    Lol, I planned on using a board and a bottle jack. I've replaced mounts in frame before just never on anything fwd.
  13. #13 Re: Popping when put in and out gear.
    The How to is located in the How to section. Ps.. Welcome.
  14. #14 Re: Popping when put in and out gear.
    Aug 2012
    Sacramento
    Ya took me about an hour or so to swap both out, the engine mount was trashed and the lower two studs didn't have nuts on them so its was long due to be replaced, now to rip out the park lock solenoid so I can get the key out..
  1. Gear selector lever popping off on 4t65
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 06:49 AM
  2. Popping
    By Kolton Lock in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2012, 05:23 PM
  3. Popping noise from passenger side when in gear.
    By aeidian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2010, 10:46 PM
  4. popping sound
    By flatblackgtp16 in forum General Tech Discussion
    Last Post: 07-30-2009, 12:15 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
