Thread: Crankshaft Position Sensor
Results 1 to 10 of 10
  1. #1 Crankshaft Position Sensor
    Sep 2012
    Calgary
    I am an alcoholic and this is my first post. Just kidding!!
    I drive a 2002 GT. THe engine would stutter and the tach would drop out to 0 and the trac off light would come on. This happed last summer and I came onto tthis site and found it was very helpful in determining the cause. It turns out to be the CPS (crankshaft position sensor). The part is cheap, from what i remember its about $85, but unless you have a lot of time and specialty tools you might be better off taking it to the shop. I took mine to a garage to get new tires and brought along the part to see if they could put it in because you need to pull the Harmonic balancer off the crank (trying to remember what i read). Anyways it would up about 2 hours labor and I was completey satisfied cause i could not have done it myself in my garage with my tools.
  2. #2 Re: Crankshaft Position Sensor
    hi.
  3. #3 Re: Crankshaft Position Sensor
    2 hours seems really steep.
  4. #4 Re: Crankshaft Position Sensor
    Feb 2010
    TN
    I just had one replaced took my guy 1 hour cost 65 plus part and welcome
  5. #5 Re: Crankshaft Position Sensor
    Harmonic balancer is a ***** to remove if you dont have a puller.
  6. #6 Re: Crankshaft Position Sensor
    Sep 2012
    Calgary
    Ya i think it was a little less but i do remember it was cheap....well worth the time and frustration without the right tool (puller...see below...)
  7. #7 Re: Crankshaft Position Sensor
    Feb 2010
    TN
    I had the puller but the way I saw it it was really hot down here for weeks on end 100 or better for 65 he could do that and I would not sweat my butt off and instead could be in my airconditioned living room finishing up my wainscoting with the TV on
  8. #8 Re: Crankshaft Position Sensor
    Apr 2009
    Fort Worth TX
    Crankshaft Position Sensor = CKP
    Camshaft Position Sensor = CPS
  9. #9 Re: Crankshaft Position Sensor
    Banned
    Dec 2012
    RichmondHill Queens N.Y.C
    Here is Your Removal tool for the Crankshaft Dampener. :-)
    Your Welcome.
  10. #10 Re: Crankshaft Position Sensor
    Never Never Land
    Old thread is old.
  1. crankshaft position sensor help
    By joshuasauce in forum Engine
    Last Post: 07-20-2021, 09:29 PM
  2. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  3. 1998 GTP crankshaft position sensor
    By phil morris in forum General Grand Prix Discussion
    Last Post: 08-03-2012, 05:52 AM
  4. crankshaft position sensor
    By brian a in forum General Grand Prix Discussion
    Last Post: 05-24-2012, 05:57 AM
  5. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
