Thread: Starter replaced, still not starting sporadically
Results 1 to 9 of 9
  1. #1 Starter replaced, still not starting sporadically
    SE Level Member cboth686's Avatar
    Oct 2008
    Canada
    Hey all,
    Another afternoon of frustration. Replaced my starter yesterday at it fired up fine. Went to the convenience store and now my same symptoms are back. All dash lights on, headlights don't dim, and car just doesn't turn over. Please let me know if you have any suggestions. I have replaced the battery and starter and fuel pump.
  2. #2 Re: Starter replaced, still not starting sporadically
    wires.
    Check all grounds and major power wires to the body and starter.
  3. #3 Re: Starter replaced, still not starting sporadically
    Oct 2008
    Canada
    The negative battery cable was recently replaced at the advice of a mechanic.. Anything else wire wise you would suggest checking?
  4. #4 Re: Starter replaced, still not starting sporadically
    Ground by the lim and icm and the ground on the trans.
  5. #5 Re: Starter replaced, still not starting sporadically
    Oct 2008
    Canada
    Sorry, am a bit of a noob. Should I just check the connections and conductivity?
    Not sure I would even know where to look...
  6. #6 Re: Starter replaced, still not starting sporadically
    Make sure they are all tight if i get a chance later i'll get pics.
  7. #7 Re: Starter replaced, still not starting sporadically
    Oct 2008
    Canada
    That would now great thank you!
  8. #8 Re: Starter replaced, still not starting sporadically
    Oct 2008
    Canada
    Does anyone thinking boosting it will help?
  9. #9 Re: Starter replaced, still not starting sporadically
  1. Bad starter???
    By rell2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2012, 09:27 AM
  2. HELP Starter?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 12-26-2010, 10:04 PM
  3. starter help
    By R3B3L 91 in forum General Tech Discussion
    Last Post: 10-26-2010, 12:37 PM
  4. Starter???
    Last Post: 09-02-2010, 12:36 PM
  5. Need help with a starter...
    By kcbuckeye2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 12:14 PM
