Thread: Front passenger wheel help
Results 1 to 5 of 5
  1. #1 Front passenger wheel help
    I live here. DirtDog's Avatar
    Jun 2012
    I have a 06 GXP NA with the 5.3L engine. I have had this small like metal on metal noise when i hit a small bump on the road. I decided to investigate it today and could not figure out what could be causing it. I did notice that on the break pads them selves they had super tiny pieces of gold like metal on them i dunno where it came from. And on everything behind the rotors was a grease like substance. It was grey and very smooth and was on pretty much everything. the car only has 43000 miles on it and I have no idea where to start trouble shooting.
  2. #2 Re: Front passenger wheel help
    Denver
    you pads have metal (among other things) embedded in them and the other stuff is brake dust
    sounds normal to me
    Jun 2012
    What about the metal on metal sounding noise that I only here when I hit small bumps? And all the grease of everything
  4. #4 Re: Front passenger wheel help
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    maybe sway bar links are bad?
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
    Jun 2012
    I guess that would explain some of it but there was an awe fully lot of grease
    Sent from my DROID RAZR using Tapatalk 2
  1. Front wheel squeeks when wheel is straight.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 06-13-2011, 07:02 PM
  2. Front passenger door is jammed
    By foxjax60 in forum General Tech Discussion
    Last Post: 04-05-2010, 10:04 PM
  3. Water in Passenger front floor!!
    By DesQ27 in forum General Tech Discussion
    Last Post: 09-12-2008, 10:04 PM
