Thread: Heavy into reverse
Results 1 to 6 of 6
  1. #1 Heavy into reverse
    May 2008
    Yesterday my 2000 GTP started getting a little heavy going into reverse from neutral or park. No bad noises or anything, just a much heavier than usual thump. I changed the filter and fluid today as it was in need of it, and that didn't seem to do much of anything for it. The magnet had the usual sludge, but nothing out of the ordinary, and definitely no chunks or free floating metal in the pan. Going into drive, and through all the gears while moving are normal.
    What might I be looking at, or what should my next steps be to determine the problem? Recently I have dropped the subframe(heavier shift was not apparent afterwards). Also just two days ago I finished replacing the struts. Is it possibly a bad axle? Passenger side is new. Driver side does click on a fully turned wheel so it will need to be done soon, but it doesn't have any wobble or shuddering while driving. Lower motor mount is also brand new, trans mount is about a year old.
  2. #2 Re: Heavy into reverse
    I'd double check the nuts on the mounts and the upper mounts. A hit when putting it into gear is often the drivetrain moving around.
    Apr 2012
    Muskegon,MI
    I had the same problem with mine until I replaced my LCA'S the other day and the loud "thump" went away when first going into reverse, but my A frame bushings were extremely blown out.
    Spectre Open cone+SD hood+Limo rear, 20% front+tinted tails+pioneer 6x9's+pioneer deck= My toy
    Tranny build this winter, then VS cam and headers the next, hopefully sooner...
  4. #4 Re: Heavy into reverse
    May 2008
    The dog bones aren't that old either, but the front lower mount did get destroyed and was driven that way for a while. I guess that would subsequently put more stress on the dog bones. I'm having a hard time remembering what it feels like with new bones. Should there be any play in them at all, or should they be pretty much unmoving?
  5. #5 Re: Heavy into reverse
    pop your hood and watch the engine as you shift it from park to rev, if the engine jerks hard and moves a lot, chances are you need new lower mounts.
  6. #6 Re: Heavy into reverse
    May 2008
    So I finally got under the hood open and took a look at it shifting. There's definitely a lot of movement. There's some movement on the bottom mounts, but I think it's more from flex. Like I said the trans mount is about a year old at most, and the motor mount is brand new. There was what I would say is significant movement on the torque struts and their mounts. I believe the mounts themselves are fine(no deformities), and that it's just the bushings.
    Is it worth trying to just do the bushings, or should I just replace them? I can get the torque struts for $11/ea, and their mount brackets for $22/ea at rockauto. I've heard that trying to press in the new bushings can be a real PITA.
  1. Looking at some new wheels. (Pic Heavy)
    By Pure2sin in forum Tires & Wheels
    Last Post: 12-09-2011, 01:57 AM
  2. Car Show *Pic Heavy*
    By Remnant King in forum Off Topic Discussion
    Last Post: 04-24-2011, 10:17 PM
  3. All About You. Pic heavy!
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 03-16-2011, 04:10 PM
  4. My New LED Tails *Pic Heavy*
    By tpalmer in forum Visual/Body Modifications
    Last Post: 06-30-2010, 08:18 AM
  5. Pics of the GTP+others (heavy)
    By 1998xGTP in forum Off Topic Discussion
    Last Post: 12-27-2008, 06:26 PM
