I just ordered a cam setup through ZZP and was wondering if I covered everything.
I bought:
XP Hot Cam
105# springs
Modified retainers
Stock timing chain
RTV Ultra Copper
Timing chain dampener
12 COMP CAMS reuseable rocker bolts
supercharger gasket (except L36/22)
2 coolant passage O-rings (except L36/22)
GM oem aluminum intake gasket set
front cover gasket
ARP assembly lube
valve cover gaskets
crank bolt
cam bolt
pcv valve
injector o rings
coolant
Is there anythingI missed or should I be golden?
